Hi Everyone - Long time troller; first time poster. Please let me know if there's additional info that would help; I'm very new to tuning...
Background:
-'07 LY6 mated to 5-spd running OE E38 (wiring done by myself) w/ '87 C10 tank, Delco pump & vette FPR
-turned off VATS & B_S2 o2s & EVAP & extra crap (THANKS FOR ALL THE GOOD POSTS ON THIS!!)
-starts up & runs consistently (though rough; see below)
Problem:
-first started engine in bare chassis in April 2014 and both B1S1 & B1S2 were bouncing fine (log file attached)
-got it wired into the truck last week and now B1S1 starts @ 450mV (with B2S1) but slowly drops to 0mV (log file attached)
Diagnostics Done:
1. suspected bad B1 o2 sensor; swapped o2s and the problem stayed with B1 (o2 sensors both work)
2. suspected i swapped B1 & B2 as others have done; swapped harnesses side-to-side and banks did opposite rich/lean (so harnesses was correct)
3. Looked for vac leaks & found none (wouldn't a vac leak affect both banks, unless right on cylinder-manifold gasket?)
It'll run in open loop (forced) and B1/B2 injector pulses are both around 3.5-4.0 ms (as in log files), but when it warms up and I let it go into closed loop, it tries to compensate for the lean condition with B1 going up to 6.5-7.0ms. I've gotten hit/miss DTC for lean on B1.
I'm hoping there's something obvious that the more experienced tuners can point out; at this point i'm about to start tearing into the rail on B1 to check for injector debris.
Thanks in advance for any help!
