Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 110
Thread: How to perform a segment swap using the segment swapper utility
    28,298
    https://youtu.be/k0dF1RQhPo4 <------Tuning school how to video
    First Open the "To" file
    Second Open the "From" file from the compare drop down(as previously stated the from file needs to have the same operating system id as the to file)
    Third click compare-Segment swapper to bring up the utility
    Lastly select the segments you want to swap, click import then close to save the file. Typically if doing a trans segment you'd by copying over the trans & trans diag portions
    And your done, really couldn't be any easier.
    Note: you should always do a segment swap to your STOCK operating system, never to a custom operating system as this can cause multiple issues otherwise.
    While we do offer segment swapping for T42 TCM's now please do not inquire to support for a compatible file as we do not have any. Thank you for your understanding.
    If you have two files that are not compatible and the segment swapper isn't selectable it will look like this. In this case it is user error and you must use two files that are compatible with one another as noted above
    May 2010
    Behind the wheel
    272
    I thought it was pretty self explanatory when I tried it. Please tell the engineers thanks for that feature Bill.
    Jan 2009
    Spokane, WA
    480
    Woot! Thanks!!
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    How close do the two files have to be in order for this to work?
    28,298
    same os id
    Darkside, AZ
    123
    Thank you guys!!
    I finally now have a shift indicator on my 2002 S10.
    1997 Black Curse SEi, 4th Engine, 2nd trans.
    2000 Chevrolet Blazer LT 4.3L
    2002 Chevrolet S-10 LS 5.7L
    Where do you download ?
    Hers -07 Jeep - SRT-8, Stock for now!
    His -05 GMC - Duramax, CCSB,4x4,LLY
    His -99 GMC - RCSB, 6.0, T-72 front mount, A/W intercooler, 4L80E, and bolt-ons
    28,298
    Email support for access
    Oct 2009
    321
    Bill,
    Will this work going from an auto car to a manual?
    Example:
    2010 Camaro A6 file. OS ID is 12635863. Want to swap to a manual trans, so I pulled another file with the same OS ID. However, the Segment Swapper utility is still grayed out in the Compare dropdown.
    Jan 2009
    Spokane, WA
    480
    No, this is for older rigs where the PCM and TCM are together.
    On your rig, simply choose 'manual trans' in the trans area. And of course take care of the other stuff
    Oct 2009
    321
    that seems way too easy....
    Jan 2009
    Spokane, WA
    480
    Quote Originally Posted by doc350 View Post
    The segment swaps are for 4l80e to 4l60e, or vice versa. There's a lot more to it than just programming, there's also wiring differences.
    On all of the GENIV stuff, like yours, trans swaps are stupid easy, as there is nothing in the PCM anymore.. It's all external in a TCM. So now you can put a 6l80 behind a 5.3 that used to have a 4l60 without issues.
    But in your case, where you are just taking an auto tune and going manual, it's stupid easy. Especially on a GENIV setup....
    Quote Originally Posted by 06MAX View Post
    So you have to download something special to do this then? Because I do not have the items above to do a segment swap.?.
    Jun 2014
    Does the pro suite have the segment swap already in it?
    Quote Originally Posted by chop30a View Post
    No, you must email support and ask for the beta version. The beta version will be sent to your Home HP Tuners page. You can then download it from there, and run it parallel with your older version.
    Oct 2009
    321
    Quote Originally Posted by waynehartwig View Post
    Nice. I like easy...
    Apr 2013
    I'm doing a 60e to 80e conversion. What vehicle should I look at for the correct trans info? Is it the main OS that has to be the same, or the trans ID? My OS is 1251050 which is a custom 2BAR MAP.
    Dec 2008
    9
    If you have a different OS , is an attempt to do a segment swap an instant disaster or a case of being totally untested and attempt at your own risk ?
    Dec 2008
    on the Dyno
    1,825
    If the OS doesn't match up the segment swapper is bleeped out on the version I am running. Wont even allow you to swap a segment...
    Located in Central Kentucky
    ShorTuning
    Advanced Tuner caesar's Avatar
    May 2003
    227
    That is done for a reason. You can only swap a segment from the same OS, otherwise you will either brick your PCM in most cases or cause the OS to read incorrect values.
