Results 1 to 17 of 17
Thread: ZF TCM - 99% Sure.....
    Oct 2007
    Crawfordville, FL
    2,415
    .... that I have located the 7,000 RPM limit that puts the car into failsafe.
    If you have a Falcon with a 5.0L and this issue, post up your file, I'll manually make the change, and we can test it.
    Eric Brooks
    HP Tuners, LLC
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    Nice one eric as this was a typical issue with the fast snappy 1-2 change throwing the car into limp mode
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Oct 2007
    Crawfordville, FL
    2,415
    Quote Originally Posted by JETURBO View Post
    Yeah, I found another parameter that probably deals with that. Its a rate limit.... RPM per second.
    Eric Brooks
    HP Tuners, LLC
    Feb 2013
    519
    I see the sct camp had it sussed a while back but good to know where the issue is
    Feb 2010
    Perth Australia
    480
    Keen to see they outcome of this Eric, My car will bang the limiter on a 1/2 shift so it's not just 5.0's that have the issue.
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
    Oct 2007
    Crawfordville, FL
    2,415
    Quote Originally Posted by hiddeous View Post
    Good to know. Post your file (or email it to me), I'll make some changes to it, if you will give me some feedback on it.
    Eric Brooks
    HP Tuners, LLC
    Feb 2010
    Perth Australia
    480
    Email sent to your address Eric.
    Feb 2010
    Perth Australia
    480
    Any updates on this?
    Oct 2007
    Crawfordville, FL
    2,415
    Have someone testing it now. Will add the parameters once I get positive feedback from the changes.
    Eric Brooks
    HP Tuners, LLC
    Oct 2011
    QLD, Australia
    436
    Hi Eric, Have you had any luck with the above issue. I'm still yet to check codes on mine, but experienced something similar on a 2-3rd shift last night with some spirited driving.
    Oct 2007
    Crawfordville, FL
    2,415
    Quote Originally Posted by 45T-XR View Post
    I have someone testing it. I just sent them an update today to try, as the first thing I send did not work.
    Eric Brooks
    HP Tuners, LLC
    Oct 2011
    QLD, Australia
    436
    There is few guys having issues with Big Converters in the ZF eric, there appears there is a max slip table, or max input vs OSS table we don't have access too, It appears the converters won't lockup and mph is way down at the track. Are you able to see if there is anything in there that could prevent the converter from locking up.
    Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
    Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
    Oct 2011
    QLD, Australia
    436
    Quote Originally Posted by Eric@HPTuners View Post
    The code I've got was P0701- No MIL- Occured on 2-3rd gearshift (might have just kissed the limiter as tacho and driver is a bit slow ) Car went into Limp mode, "D" flashes on the dash. Had no auto kick down etc in limp mode. Thought I'd finally snapped my cryod input shaft but still had drive. Coasted around into a car park, shut the car down, fired it back up and all was good again. This is the first time I have experience it- but it sounds similar to the issue the other guys are getting.
    Mar 2015
    26
    7000rpm testing success
    Just wanted to pass on my thanks to Eric for sticking with this, not a huge deal for the T6 owners out there but us V8 guys need the rpm badly if nothing more than not stuffing up runs at the track trying to extract the last bit of performance. I have data logged a heap of 2-3 shifts past 7000 rpm and also some 1-2 shifts which exceeded both rpm/sec rates and the 7000rpm limit and no trans faults at all.
    Here's a quick vid taken
    http://youtu.be/poamZt-cWrw
    The rpm change rate "trans fault" affects almost everyone with wheelslip on gearshift so I am sure you can take advantage of these finds Eric has made.
    Daniel
    Jun 2014
    Eden
    88
    what needs to be adjusted to fix it?
    Thanks for your help
    Mark H.
    Oct 2007
    Crawfordville, FL
    2,415
    Quote Originally Posted by Huddo View Post
    I manually adjusted some things in Daniel's tune. I'll be adding the parameters today.
    Jun 2014
    Eden
    88
    thank you.
    Mark H.
