If you use closed loop operation (SD or not) you will be using the o2 crossings tables. I do believe that the Dynamic Airflow will put you into the right Mode though as they are very close except on transitions.Originally Posted by RoninsDenali
I created a custom PID to see the % difference between MAF and Dynamic Airflow. Very telling during transitions!
EC
