F Tune x 95 MAF VE.hpl
I have attached a log file I did yesterday. The changes you gave me seem to work great.The AFR is almost exactly what the commanded is.Its a lot leaner.I guess I`ll read up on setting the MAF and VE tables. It looks involved,but thats how you learn. Along with help from an expert tuner.I do have a question or two. Is changing the AFR in PE done with the Engine-Fuel-Power Enrich-Power Enrichment-EQ Ratio table? What does the VE table do? I assume that the MAF and VE tables got screwed up with all the airflow changes that I did to the engine (5.3-6.0,larger T/B,Square port heads with bigger valves,cam,CAI,Long tubes,4"exhaust,etc.)? Thanks again for the help and advise.I do appreciate it.Bill
Thanks again for the help,I appreciate it.
