Results 1 to 3 of 3
Thread: Scanner not reading AC pressure voltage
    Nov 2016
    19
    Hello, I am tring to add wide band to AC. The problem is it will not read the voltage coming from the wide band. AC pressure stays at zero. I am using pin #11 on the red c2 connector. This is my ECM info. Any help would be appreciated. Thanks.
    ECM: 10, VPW
    VIN: 2GCEK19T8Y1103511 - 2000 Chevrolet Silverado 1500, 5.3 L, 8 Cyl, GM_P01
    Serial: 2DG0KH969203
    OS: 12205612
    Nov 2016
    19
    What, no one can give me a pin number or verify wire color? Thanks!
    13,582
    http://lt1swap.com/99-02_vortec_pcm.htm
    I use the EGR circuit myself, it's was easier because I kept my AC working.
