We have a 2004 Zo6 running a Vortech SQ Trim supercharger system with gaseous intercooling.
It is running 5 - 6 lbs. boost
When it was dynoed it hit 428WHP at below 10.1 AFR... it was off the chart so I dont know the exact number. It smells like gas and blows black smoke, so its purrty fat. Before now all of our tuning was done by sending out the program, having it edited and sent back. Now we will try to do this ourselves.
We have 42lb injectors, and the Fuel pressure is at 60 PSI. The injector rated fuel pressure is, as I was told, 90 PSI.
Stoich AFR is set to 14.57
Right now the the PE table is as follows -
0 = 1.203
400 = 1.203
800 = 1.203
1200 = 1.197
1600 = 1.192
2000 = 1.226
2400 = 1.226
2800 = 1.218
3200 = 1.229
3600 = 1.229
4000 = 1.254
4400 = 1.277
4800 = 1.294
5200 = 1.292
5600 = 1.292
6000 = 1.292
6400 = 1.292
6800 = 1.292
7200 = 1.292
Injector Flow Rate vs. KPA VAC -
0 = 39.44
5 = 39.62
10= 39.81
15 = 39.99
20 = 40.18
25 = 40.30
30 = 40.49
35 = 40.68
40 = 40.86
45 = 41.05
50 = 41.23
55 = 41.36
60 = 41.54
65 = 41.73
70 = 41.85
75 = 42.04
80 = 42.23
I plugged our numbers in to a Spreadsheet on RedHardSupras site, and it wanted us to change the IFR table and put lower numbers than what is above, ranging from 34.29 - 35.31. I found that odd it was lower than 42, but I tried it anyways. Well it smelled like a boat and the O2's were reading 1200!! so I put that back to normal.
Any ideas on how to get the PE AFR to around 12.8 ?? While cruising around we get about 27 MPG on the highway closed loop.. it runs pretty good. Not sure if I should mess with the VE table or not.. or if I have something set wrong with the injectors since they are larger and the fuel pressure is at 60 PSI not 90 PSI.
Any thoughts?
BTW I dont have the .bin saved on this computer that's why I had to type the numbers in. When I get home I will fix it so you can actually see the file itself.
