I'm using the Idle airflow Config. Could someone tell my why my Base Running Airflow> Idle Airflow numbers are so low. I look at other tunes and their numbers are so much higher. Sometimes double.
Am I doing something wrong? I want to make sure I have an accurate starting point for my idle tuning.
Attached is the tune set up for idle airflow tuning and my log.
Thank you and Happy 4th!!
My SD 80lb inj. BRA.hpt <<<<Tune
7-4 idle airflow in gear.hpl <<<<Log
