Page 6 of 7 FirstFirst ... 234567 LastLast
Results 101 to 120 of 125
Thread: Have a scenario that requires expertise advise
  1. #101
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    OK, BRAF adj....140F = 11.6 and 176F-284F = 9.5 g/sec.
    What about the wideband, is it working or not. Doesn't seem to be.
    Guess you are ready to go tune it.....finally. Still have to say the IAC not getting to 60-80, the MAP being 33-37kPa and the VE being as high as it is doesn't pass my sniff test but it runs, so....
    Ed M
    [email protected]
  2. #102
    Advanced Tuner Cyrperformance's Avatar
    Apr 2014
    Haines City, Florida
    325
    Not sure about the wideband yet, selected the PID under Wideband O2 AEM. You had me flippin, you give the adjustments in metric and the temps in imperial I thought "well something is wrong with this file not showing me the temps"! I have to look into the wideband and how to set this one up correctly. I have 2 LC-2's which are pretty easy to setup but have never used this one before.
    2006 Escalade LMM Duramax Tuned
    2000 S10 Twin Turbo 6.0L
    56 GMC 100 Status Unknown
  3. #103
    Apr 2014
    325
    Just so I understand, you are using the histogram details to make the idle airflow adjustments, correct?
  4. #104
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by Cyrperformance View Post
    Sorry, that's what i am comfortable with...:-)
    Are you good now to move on? Do you have a dyno? Are you looking for a tuner? Check out my website.....
    Ed M
    [email protected]
  5. #105
    Apr 2014
    325
    I did check out your site, where are you located?
  6. #106
    Mar 2007
    Florida
    3,772
    Boynton Beach...
    Ed M
    [email protected]
  7. #107
    Apr 2014
    325
    Oh, a little ways from here. Gauge is showing dashes and I input the linear offset and it reads 17+ in scanner so needs adjusting.
  8. #108
    Mar 2007
    Florida
    3,772
    I can tune remote...do Long Island, Norway, Calif, Ill etc....
    Let me know if you need help with the wb, will hook in and show you our service if you would like,
    Ed M
    [email protected]
  9. #109
    Apr 2014
    325
    I think the AEM wideband in the list has the correct settings but it is dead lean at 18.5+, gonna mess with it some more but would like to get some pricing from you if you want to shoot me a PM.
  10. #110
    Apr 2014
    325
    When I say dead lean the gauge dashes out it is so far over. I can add to the VE like before, I think it was 125 in the idle region it will come down to 13.5- 14.9 ish depending
  11. #111
    Mar 2007
    Florida
    3,772
    Sounds like that is right...add it in. You can give it some pedal and move up in the table and see if the trend continues.
    Still a bit confused why the IAC wont come down but go with what the motor says it needs.
    Ed M
    [email protected]
  12. #112
    Apr 2014
    325
    So little update here mowton, I went back through my plan book and found that I chose this sensor as it is the same in my Duramax. So I opened the stock file from that and the map values are 43.81 and 366.7. I have saved those in and will try that tomorrow afternoon. I did notice that as I got into the gas the map reading actually went from 30kpa down to around 11kpa. Definitely not correct. Hopefully this will resolve the issue.
  13. #113
    Mar 2007
    Florida
    3,772
    So its working backwards????? I gave you 366 (assumed to be linear) and 33 (assumed to be offset), very close but you are stating the other way around....does that mean anything? Very weird. Maybe you should try the 1 bar sensor again with the 94 and 10 and see what happens.
    Thanks for the update
    Ed M
    [email protected]
  14. #114
    Apr 2014
    325
    Sorry, 366 43, the 10 should be 43.81, but yes it is running lower kpa when throttle is applied.
  15. #115
    Aug 2012
    SV, AZ
    447
    I haven't looked because I'm not on my laptop, but what do you have stoich set at? Is your injector information loaded correctly? I just read that you have crazy ve values at idle and injectors is where I looked first.
  16. #116
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by Eaglegoat View Post
    Its MAP related....
    Ed M
    [email protected]
  17. #117
    Apr 2014
    325
    I don't know what is going on with the map, I have changed settings to one bar same, going to load stock file and see what happens with the stock sensor then trace map wires to make sure they aren't damaged in some way.
  18. #118
    Apr 2014
    325
    I used voltmeter on MAP plug and the ground is good and the 5V reference is good with key on. Traced the signal wire to the PCM and no issue there. Not sure where to go from this point as everything seems to be in order.
  19. #119
    Apr 2014
    325
    I load the stock file and in the scanner it shows MAP SAE 101kpa and MAP V 4.82. Here is a log with just key on after loading stock file.
  20. #120
    Apr 2014
    325
    Back to the 3bar OS and key on 0kpa in the MAP 3bar PID. With the same connection change PID to MAP SAE and it reads 105kpa Key on. Tells me that it is something in the scanner or the 3bar PID no?
