Page 5 of 21 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 419
Thread: 2015 GT Valve Overlap Tuning
  1. #81
    Jan 2013
    Hawaii
    2,101
    I get error E101 saying your log needs to contain Time, Rpm, Throttle position. My log has them in it. Im going to try and make a log with only those three values in it and try when I can.
  2. #82
    May 2015
    427
    VD works fine with 2.25. Just go into the log in excel and change the names of each monitor logged to what you want. Make sure time is time, rpm is rpm, and tps is tps, rest is moot.
  3. #83
    Jan 2013
    Hawaii
    2,101
    ahh gottcha thanks
  4. #84
    May 2015
    427
    Well, after a few hours of bracketing the intake and exhaust cam angles. This is what I came up with. UPDATED!!!
  5. #85
    Mar 2010
    Texas Hill Country
    3,299
    what did you do to get into OP?
  6. #86
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by kris5597 View Post
    Even when I have tried to advance the cam passed the -20* advance in the VCT table, the engine will not advance past it. I have reason to believe, this is the table limiting it. At the bottom of my attachment.
    Attachment 54059
    Kris
    -20 is the cam phaser limit for the intake cam on the 2015
    Eric Brooks
    HP Tuners, LLC
  7. #87
    May 2015
    427
    So -20 is the absolute max advance on the 2015. If you take the base position into account, you can get a decent amount of advance, but not as much as the previous coyote.
  8. #88
    May 2015
    427
    Quote Originally Posted by Higgs Boson View Post
    Enable it in the mapped point configuration and adjust the OP mode enabled load and pedal position accordingly.
  9. #89
    Mar 2010
    Texas Hill Country
    3,299
    yeah, mine still won't go.
  10. #90
    May 2015
    427
    This seems to be a common issue. That's all I did and mine definitely works. I don't believe it shows that it's in OP mode in the scanner when viewing the mapped point load, but my car definitely runs OP mode VCT and other tables.
  11. #91
    Mar 2010
    Texas Hill Country
    3,299
    What is "Distance along Mapped Points" for VCT?
  12. #92
    May 2015
    427
    Not sure, where is that located?
  13. #93
    Jan 2013
    Hawaii
    2,101
    air flow> variable camshaft > distance tables
  14. #94
    May 2015
    427
    I'm not sure. I have not made changes to these tables. Not sure what they do. They don't seem to be targeted towards WOT.
    Kris
  15. #95
    May 2015
    427
    Just to revive this thread on a similar topic. I recently tuned a 2012 5.0 with intake, catback, and cat deletes. I completely retuned the intake VCT from 50 degrees to 10 degrees of advance with the exhaust cam locked at 0. After the intake cam was completely dialed in with the exhaust still at 0 the car made peak power at 6200rpm. Every 5 degrees of retard on the exhaust cam would pick up 10-15 whp everywhere and peak power would move up 200-400rpm. After the tune was finalized, said car made peak power at 7100 rpm with holding peak torque from 4000-5500rpm.
    Kris
  16. #96
    Kris,
    When you state you re-tuned VCT from 50 to 10 degrees, do you mean that's the range that you ended up with, or you changed from 50 degrees to 10 max timing on the intake cam?
    Any chance you are willing to share where you ended up with the timing curves? I have a similar setup as the car you just posted about.
    Im still confused why I see such big differences in peoples posted cam curves on bollt on Coyotes with stock intakes manifolds.
    David
  17. #97
    May 2015
    427
    Hi David,
    When I say I tuned the vct from 50-10 degrees of advance, I mean I bracketed the cam angles. Locked the intake cam at 50 degrees of advance from 1000-700 rpm and did a dyno pull, then locked it at 45 degrees and did a dyno pull, then 40 degrees, and so forth all the way to 10 degrees. By doing this I am able to see which cam angles make the most torque at a given rpm. Once the intake cam is dialed in, I then retard the exhaust cam in 5 degree increments until there is no longer power to be made doing so. I'll post my VCT tables tomorrow.
    Kris
  18. #98
    May 2015
    427
    Here are the VCT tables from the recent 2012 5.0 car I have tuned.
  19. #99
    Kris,
    Sorry for the delay, I just noticed you posted the tables. Thank you very much!! Really appreciate it.
    David
  20. #100
    Kris,
    Do you have any opinion on where the cams should be for part throttle for max torque? Im thinking of passing where you want the torque to be there even when part throttle. Do you think the same Cam timing would be around the same as for full throttle?
    David
