Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 102
Thread: Piston faliure 6.2 whipple 7psi
  1. #81
    Sep 2013
    SF Bay Area , California
    159
    It's too bad you don't have the tune file to share. I'll bet KR was not pulling enough or completely disabled.
    2001 Z06 : 856/830 : Built LQ9 403ci : D1SC 17psi : Self-built , self-tuned.
  2. #82
    Tuning Addict
    Jan 2015
    6,813
    Quote Originally Posted by Redline MS View Post
    why? Who decided that 11.5-11.7 is the best? The internet.....the reality is that much of the additional fuel (above what you would consider reasonable for a NA motor) is for cooling. DI blows un-vaporized fuel right into the chamber where it has a tremendous capability to quench (cool) the combustion temps. This allows the ability to run a leaner AFR then what we are used to in port fuel engines..
    The bottom line is there is a range that engines like to run at for good power but there are many factors that can effect what is really the best. Different fuels react differently, as well as how efficient a combustion chamber works. The GEN5 cylinder head is very efficient which is another reason you can run leaner. Unless you can spend enough quality time on a dyno its hard to find this.
    Higgs,
    The injection timing strategy with this controller is much more complex then what we have available with the current tables. We are getting ready to test an engine in which we installed EGT probes which will really give is some insight as to what direction we should be going and why. As stated earlier even the WB is not telling us the full story when it comes to what is going on it the chamber. EGT's will offer another "dimension" into what's happening. The math is driving me nuts as there has to be some other factors that offset timing based upon airflow changes.
    I'm still wondering if your LT4 fuel hardware changes require more that is in a LT4 OS that is causing some of your issues....
    Really stupid question I'm sure, but what would everyone on here consider a safe EGT for DI or any gas motor? I've always believed in plug reading. Probably shoot way too rich with my own readings. I like to see a nice "darkish" brown color on my plugs and in the combustion chambers or at least the valves durring re-inspection tear downs. Guess I air too much to caution, but doing it this way gets me the same power on a hot motor as it does on a colder motor. Then as of now I've just been adjusting injection timing for "fuel useage" optimization. Just figured this was showing the most efficiency? I know it's not precise and could be adjusted better, so I'm really curious on "goaled" EGT's...
    ~Greg Huggins~
  3. #83
    Sep 2013
    159
    Good question , haven't explored EGT's yet. I've heard 1500-1700, but what puzzles me is that I read going too lean can cause EGT to drop.... I would think that would produce more heat and higher egt
  4. #84
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Plug reading may be fine for WOT but part throttle not going to happen. The proper way to read a plug is to go WOT, shut the motor off and check. Driving around and then looking at a plug in a closed loop fueling system is hard to quantify anything. The EGT reading is to be combined with lambda. You can have EGT's to the extreme of rich and the extreme of lean so you need to have another "check" to ensure this. Much of what drives MAX EGT is the parts....at some point aluminum melts....that's to hot! If I had to stab a temp range it would be between 1100-1300 but again much like spark timing and fueling its dependent on many other factors.
    As we have discussed in prior threads; if you air model is correct and your injector data is correct, its still possible to have the wrong AFR due to injection timing. DI is so prone to poor cylinder mixing (when SOI is off) that your "reported" AFR can swing rich very quickly which would normally have you change your air model to solve. Not only is this a problem in fueling but since the torque model is tied to airflow you just messed that up to.
    Regarding the plug reading; the real reading is down in the base of the plug. We have a tool that cuts the threads off the plug to get to it and we mostly look at it to see where we are on timing.
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
  5. #85
    Sep 2013
    159
    Yes , I only use plug reading for wot. Checking the annealing point on the ground strap has been incredibly useful and is so easy to do. It's basically telling you , this is the peak cumulative combustion temperature that was reached during the pull. Too high and you start to melt things , too low and you can turn it up more. However , I've chased my tail before thinking I had gone too far when in actuality the annealing point hadn't even started to show yet. It takes a some getting used to and different brand plugs will show different color markings.
  6. #86
    It definitely looks like the lt1 has inherited the weak rear cylinders of the ten IV and III, I would be nice if gm had a coolant crossovers like the 97-98 motors had. There are aftermarket solutions.
    99' SS LSR 388 twin ETR billet 76s, glide, etc
    06' C6 Z06 885rwhp/796rwtq [email protected] E85 940/840
    07' TBSS Turbocharged 6 psi 525/505
    16' C7Z A8 Stock blower slow street car 815 RWHP
  7. #87
    Sep 2013
    159
    Quote Originally Posted by Nick@Newtech View Post
    Did they do away with the rear crossover because the intake manifold is in the way?
  8. #88
    Yup
  9. #89
    Jun 2006
    536
    Hard to believe that they still haven't addressed these things.
  10. #90
    Dec 2008
    on the Dyno
    1,825
    The key is to use ALL of the sources of good data you have available to give yourself the intel to make a decision on what to do next. Does it need more timing, more fuel, less timing, less fuel, more cam advance/retard, more/less SOI timing etc.
    You leave data on the table if you don't look at the plugs especially from the problematic/hot cylinders of the engine. This is obviously with fresh plugs and WOT pulls and shut down only. I've seen physical signs of detonation on plugs that the knock sensors didn't pickup. Which do you believe at that point? Like I said you have to take a total grasp of all the data to determine what the best course of action is to move forward with the calibration.
    Located in Central Kentucky
    ShorTuning
  11. #91
    the OP mentioned 15 degrees at WOT.... like a block of 15 degrees? or 15 degrees at peak power? i've tuned quite a bit of gen 5's now and having a block of 15 degrees would definitely be an issue, especially down low and through peak tq in a 5000+ lb truck. what did the timing curve look like?
    Owner of Cunningham Motorsports
    06 z06
    2016 camaro
    68 Camaro
    2014 e63 amg
    07 LBZ Duramax
  12. #92
    Sep 2015
    31
    I work on lots of these engines and even stock it happens in number 8 ... ive seen the piston in the bottom of the pan. Ford will warranty this as defective.
  13. #93
    Advanced Tuner AutoWiz's Avatar
    Aug 2015
    South Florida
    449
    Just thought i'd post up a picture from the matrix. rofl. for all of your enjoyments..
  14. #94
    Sep 2013
    159
    Quote Originally Posted by AutoWiz View Post
    No one likes a showoff, lol.
  15. #95
    Aug 2015
    South Florida
    449
    I understand and agree that hptuners has a nice gui, but honestly, don't you think that video card is a bit overkill for hptuners?
  16. #96
    Sep 2013
    159
    Overkill? Never heard of it.
  17. #97
    Jun 2009
    usa
    27
    it would be nice if they made spark plugs with egt in them for tuning.and a vibe transducer for each cylinder.
    some good info here thanks
  18. #98
    Baltimore, Md
    1,208
    That doesnt "fix" the back cylinders dying first. Ive seen just as many LS1 coolant crosssover cars melt the back two holes as the rest of them
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
  19. #99
    Quote Originally Posted by GrannySShifting View Post
    I agree its not a fix but it seems to help keep things more even. Doing a plug read after a pull on the dyno you can see the timing strap seems to be farther down on the rear cylinders than the front cylinders, on the flip side of that I have seen the exact opposite on various setups. Only other things i can think of would be distribution of air mass and or fuel, something a lot of tuners don't think of also is spark advance is usually global value, whats good for some cylinders are not good for others. this ultimately is what kills the one or two cylinders and the rest are fine.
  20. #100
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    You can dial timing up or down on individual cylinders vs. rpm in the Static Retard table.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
