how can i tell what my ECM ( PCM ) is for ? i think it for a 01 or 02 camero what do i use to check
i check my last scan and under OS i found 12212156
thanks
thanks
P01 which is an 512kb LS1 style
thanks bill . i think i have the wrong sensors or something , i am trying to figure it out ,, my pass side matches up the drivers side dont match
on mine i have pass side bank 2 sensor 1 right front matches up
on mine if you look at the pics bank1 sensor 1
i have
A =black
b= pink
c=tan/wht
d=prup/wht ,,
might be getting some were , were i still dont know
unless i can run the same sensor on both sides ??
well back to square 1 took apart my sensor plugs matched them up how i thought i they was supposed to be ,
i think they should go
blk =sig pos+ to pink
gray = earth to ground blk
wht =heater to tan 1 side and tan/wht other side
wht= heater to ppl 1 side and ppl / wht other side
still no good got this
either i still have bad wiring ot my sensors are bad
well i took 1 of mine out and check the heater wires ( white ) and the have about 7 ohms ,, i checked the other 2 wires ( tan & blk ) with a torch and heated them up and got nothing ,, so i might just have 2 bad sensors they was new when i installed them in nov , i have about 1700 miles on them
i am going to by 1 tomm and try it and rescan the car and see maybe that's all is wrong
