Results 1 to 12 of 12
Thread: Can you see why this car never goes into closed loop?
    Baltimore, Md
    1,208
    Because I havent been able to figure it
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    Apr 2015
    302
    You have your LTFT enabled and your STFT disabled, shouldn't that be the other way around?
    What is closed loop?
    Baltimore, Md
    1,208
    Thats disabled in openloop. I want full closed loop operation, but I can enable that as well and see
    Tuner POWERZONE's Avatar
    Jul 2014
    HOUSTON,TX
    191
    Go to
    Engine>Fuel>Open/closed loop>closed loop proportional
    *Set this table back to stock
    Engine>Fuel>Open/closed loop>airflow mode
    Try this and see if this works.
    POWERZONE- AUTOMOTIVE PERFORMANCE AND TUNING SOLUTIONS
    STREET TUNING/DYNO TUNING/TRACK TUNING/REMOTE TUNING/EMAIL TUNING
    [email protected]
    405
    2,326
    Quote Originally Posted by POWERZONE View Post
    Go to
    Those tables are stock in the file he posted.
    Quote Originally Posted by GrannySShifting View Post
    You have no O2 sensor activity. They look to be either unplugged or dead sensors. You should be setting inactivity codes for B1S1 and B2S1. It will not enter closed loop with no O2 activity or with S1 O2 codes set. Log Fuel System Status and see if it is in OL Fault.
    Feb 2009
    1,931
    ^^What he said and same answer as last time you asked. Its not the tune. Its wiring or 02 sensors or pcm related.
    Sep 2013
    427
    2*LS1 is right , check your 02's either not connected or their finished....Your dtc's should be setting inactivity for both banks....he is right no activity no closed loop operation...Good point click on status see what that is reporting....Cheers Bret@ultimatelsxtuning
    Jul 2014
    HOUSTON,TX
    191
    Quote Originally Posted by 2xLS1 View Post
    Ok. I compared a 99 auto file vs. 99 manual file. The auto tables are different.
    [email protected]
    Baltimore, Md
    1,208
    Thats what I thought, but the guy insists he has power and ground on the right circuits, continuity to the pcm on the signals and two brand new O2s!
    May 2014
    8
    I know this is an old thread, but I?m having the same issue and can?t figure out what is causing it. I have new sensors installed. They seem to be getting power. No codes. Won?t go into closed loop.
    Baltimore, Md
    1,208
    Quote Originally Posted by rijrunr View Post
    I was never able to figure this one out
