Results 1 to 18 of 18
Thread: Fuel injector data needed #12609749 gm or Ac delco 217-3410
    Sep 2015
    23
    I'm ordering these Ac delco injectors for my car so I'm in need of the injector calibration data if someone could supply it. Thanks
    Just download the 2009 Hummer H2 with 6.2L from the Tune Repository. The file has the injector data you need.
    -Greg
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
    Sep 2015
    23
    Ok thanks. So just set my fuel reg to 58 psi? Do I have to use the vacuum port or can I just run a set 58 psi? I have a return style reg from fast
    Aug 2012
    SV, AZ
    447
    Post your tune. If the data needs converted I'll do it for you.
    Whether you run the manifold reference on your regulator or not is up to you, but I need to know what you plan to do so I can give you the right data.
    Sep 2015
    23
    I'd rather just run a steady 58 no vacumn. Thank you!
    Sep 2015
    23
    I don't have the engine or wiring harness hooked up yet so I don't have a tune yet. It's just a stock 411 ecm I bought for now
    Aug 2012
    SV, AZ
    447
    Ok. I'll post the data when I get home later.
    Sep 2015
    23
    Thanks a lot
    Aug 2012
    SV, AZ
    447
    Here you go Frank. Let me know if there's any questions. This is set up for 58psi with no vacuum reference.
    frankg.xlsx
    Jun 2017
    Oxford, OH
    22
    GM 12609749 Injector Data for E38
    I am trying to switch to these in an L92 engine and need the injector data for an E38. Does anyone have it in the right format, now that the repository is MIA? Here is the tune. Thanks in advance.Matt's 72 Cutlass.hpt
    Jun 2017
    Oxford, OH
    22
    Can someone please share this data or maybe give me a hint on where to find it?
    Feb 2015
    Perth, Australia
    974
    try copy data from this stock file for the injectors
    stock.hpt
    Dec 2020
    Quote Originally Posted by Eaglegoat View Post
    frankg.xlsx
    What is one to do when the offset vs volts vs vas conversion map is plotted on a different axis than the tune file im working with?
    Tuner nathanhine1977's Avatar
    Oct 2019
    Darwin Australia
    52
    Can anyone convert stock LSA injector data (GM#12598646) (Bosch# 0280158187) to be used in an E40, suit application Magnuson 1900
    Jul 2021
    5 years later - This is what I need for my project, Thx a lot for sharing
    Jul 2021
    frankg.xlsx
    Feb 2021
    I was looking at this because I just put 749's (54lb) injectors in my 2010 Sierra. Lukearmstrong's file shows roughly 41.8 lb at 400kpa where my yukon 6.2l flex file has different numbers. Mine show roughly 50lb @ 400kpa. GM did put out two very close injectors 12609749 and 12613412, I wonder if that's the difference. Makes me wonder if I have the wrong data now??!!
    7,837
    They are different injectors with different data used in different engine RPOs. There's no reason to assume any specs will carry over between two different part numbers just because they have the same exterior dimensions. Check the VIN of the tune file you pull data from - 12613412s are used in L96 (8th VIN 'G'), 12609749 is L92 (8th VIN '8').
