Working on a new setup and trying to figure out the best method in tuning this thing. The factory has it setup to run speed density up until 4000rpms and transitions over to the MAF. Initally I turned the MAF on at any RPM over 100 and started tuning it. After thinking about it, I did some time on the street tuning it with speed density turned on until 4000 rpms and the MAF above that. Set some conditions in the histograms so it only logged the user inputted VE table below 4000rpms and logged the balance of the data on the MAF table. Its going to have a supercharger at a minimum, probably SC + blower cam and possibly a set of heads. I like the idea of using SD down low as it gives you more resolution in fueling and then simply use the MAF up top where your 75% TPS or greater.
Phil
