2013 Dodge Challenger R/T 5.7l Auto 5sp
Mods: CAI, 180* Tstat, JBA ceramic coated long tube headers into catless mids, into a 3" Heartthrob exhaust.
LC-2 wideband but not tied into my HP Tuners yet so I'm using Logworks. The wideband was calibrated and it does appear to record properly at part throttle.
I am running 93 octane with as much as 10% ethanol
I've been slowly tuning my car and I have the fuel trims adjusted to where they are pretty good. The ltfts are <3 and stfts are <5 in the majority of the fields. I have finally started doing WOT runs to adjust timing and fueling and I have a question.
Stoich is stock at .0688 and I've not changed this.
Question 1: I believe a fair target AFR on these hemi engines is 12.0 - 12.5: Is that a fair statement? I have read where others have gone even more rich.
Question 2: How quickly should I expect to see the car adjust the AFR?
Looking at the Logworks, I expect to see the AFR jump up during the shifts but it seems like it isn't moving to the 12's very quickly.
Question 3: I noticed that my TPS% maxes out at 86.x% while WOT. Is that normal?
Here are a couple of pics. One is of the Logworks. I was sitting at an intersection where I waited a bit to make sure there was no traffic before doing the run. I pulled onto the road and didn't just mash the pedal because I didn't want to spin the tires.
Also, I copied the FA Power Enrich into Excel, then added it to Stoich and used another table to show the inverse (AFR being commanded) for reference.
