Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 82
Thread: Chrysler SKIM Thread 2.0
  1. #41
    Potential Tuner wogboy's Avatar
    Apr 2020
    Tasmania
    5
    i have a 6.1 gen 3 out of an 07 300c SRT in an Aussie valiant charger and have successfully disabled SKIM, it starts and runs with the SKIM module disconnected
    2017 Mustang GT 5.0 Coyote 289 Rwkw
    2013 Holden SSV Redline 6.0 LS2 Ute 340 Rwkw
    1987 HR31 GTS-R Skyline 430 Rwkw
    1973 VH Charger 6.1 Hemi in the making
  2. #42
    Sep 2010
    FL
    375
    Quote Originally Posted by wogboy View Post
    How did you do it?
  3. #43
    Apr 2020
    Tasmania
    5
    just using hp editor, under the system tab, in general is SKIM able and disable, click on disable in both boxes, make sure if you have a SKIM module it's unplugged, the flash the ECM, done
  4. #44
    May 2015
    39
    Is anyone else able to confirm a successful skim removal? I'm reluctant to burn up credits trying.
  5. #45
    Tuner in Training iCanuck's Avatar
    Apr 2020
    Vancouver, BC
    30
    Not sure I even understand the point of disabling skim. So you can use unprogramed keys/fobs? PCM swap without Vin writing?
    In the newer years where BCM and RFHubs are used this is next to impossible as the skim is used in many modules. The older years I could see it where the skim and win modules are used. But still don?t get the point of it.
    You want to get past skim... buy a OBDX+ and AlfaOBD and goto your dealer with your insurance papers and ask the parts/service dept. for your skim code. You can program and initialize most modules that require skim codes.
  6. #46
    850
    Quote Originally Posted by iCanuck View Post
    That's interesting. Guess I'll be calling my buddy at the dealer later today to ask about my skim code and my fob PIN.
    Can you use AlphaOBD on a 2015+ to change a VIN or satisfy SKIM when using a PCM (or any other module) from a salvage yard for repair?
    I believe most people want to eliminate SKIM to simplify the wiring harness and modules needed when retrofitting an older vehicle with current drive train and a factory PCM/TCM.
  7. #47
    Apr 2020
    Sorry for the possible wrong placement of post please just hear me out.
    Hi, the name is Boz. I have a 2005 300c SRT8 car number 44. The gauges and winshield wiper harness caught fire on Christmas Eve with my wife and I in the car. Under the hood is fine and still original including wire harnesses. I have changed the complete dash and all modules on the interior. I?ve connected my old ass Diablo tuner to it and connected with my ecm and successfully restored my original back up. Now when the lock smith tries to reprogram a wireless control module, or SKIM, or whatever it is, he can?t connect to my pcm/ecm to change the vin in the module. He took the module saying he?s going to manually insert my vin in the module at his shop and that I must have a connection error somewhere. Well the car started and ran for a couple seconds three times. So it has to have some type of ability to run. Any help y?all can give me would be greatly appreciated. I?ve never done something this in-depth but I?m pretty far along to the point that when my Braum seats come in, in a couple weeks I should be ready for inspection to get her road legal again. My only dilema (so far) is this bullshit anti theft and SKIM crap. I?m no rocket scientist just a guy trying to bring this thing back to life. There?s a lot of sentimental value attached even tho I haven?t owned it long. Any help will be greatly appreciated. I?m am sorry for the long post but this is the first thread I?ve come across where it seems like I could get some help. Thank y?all.
  8. #48
    Apr 2020
    Also if it?s easier you can email me at [email protected]. Again, thank y?all for the time.
  9. #49
    Jun 2020
    Hi do you still have that file? Do it will work for grand cherokee 2000 4.7 v8? I broke the skim module...
  10. #50
    Sep 2010
    FL
    375
    I can delete SKIM on the older PCMs now. Unfortunately, it wasn't HP tuners that made it possible. And it cost me about 2 grand to make it possible :-(
    I should be able to delete SKIM on all those older 3-connector Dodge PCMs, probably from the 96-04ish era.
  11. #51
    May 2020
    3
    Quote Originally Posted by pontisteve View Post
    Buy a DRBIII? I've been thinking of doing so myself..
  12. #52
    Sep 2010
    FL
    375
    Quote Originally Posted by taco_nights View Post
    No, but that would probably work too.
  13. #53
    Mar 2020
    9
    Please explain how you would use the DRB 3 to disable SKIM. I only find the options in my DRB to enable SKIM, AFAIK there is no way to disable once enabled through factory chrysler tools.
  14. #54
    Sep 2010
    FL
    375
    Quote Originally Posted by luke4010 View Post
    Does DRB have the ability to reset SKIM? And to change VIN?
  15. #55
    Mar 2020
    9
    There is a "reset skim" procedure but it does not wipe the VIN, i.e. no noticeable effects. The DRB can program VIN into a SKIM or PCM module but only new ones, once a VIN is programmed you can view it but not change it. I've never been able to enter the VIN via DRB anyway because normally you use the "PCM Replaced" or "SKIM Replaced" functions and it copies the VIN from either the PCM or SKIM, whichever was not replaced. I used my HP Tuners software today on a 99 XJ to disable SKIM in the PCM and it worked. But I unplugged the SKIM module before I flashed the PCM with the tune.
  16. #56
    Sep 2010
    FL
    375
    I believe it's necessary to reset SKIM and reset the VIN, then unplug the SKIM module before powering up the PCM. I'm surprised to hear that HPT worked on the 99 XJ. I was under the impression that HPT never worked.
  17. #57
    Apr 2010
    45
    So did you write entire or just tune?
    THanks
  18. #58
    Sep 2010
    FL
    375
    Quote Originally Posted by jhertel View Post
    THanks
    I did not use HP Tuners.
  19. #59
    Nov 2020
    Yeah skyed isn?t able to delete skim with Dodge tried him recently. The crate engine pcm works great just hot wire to starter (two wires). Works in 2015+ models with no repinning needed.
  20. #60
    Sep 2018
    30
    I have found that the settings in HPT don't seem to do anything for Canada/USA programmed PCMs, but does have an effect when Euro programming is used.
