Results 1 to 8 of 8
Thread: unable to read/display DTC codes after 3.0 download
    Advanced Tuner Japeatr's Avatar
    May 2010
    Dallas Texas
    321
    I was trying to read codes on a '08 Cobalt SS (LNF). it would grey out when button was pressed in scanner but then would not display any codes, just blank fields. MIL was on.
    384whp/303wtq
    Built 2.0LSJ: TVS w/2.6, 1000cc, Stage 2 cams, custom fuel system, E85, Dual Pass, 3"intake, 3" Catless exhaust, CIA midlength Header
    Sep 2002
    Chicago, IL
    6,397
    Does it detect any freeze frames?
    We got this guy Not Sure, ...
    May 2010
    Dallas Texas
    321
    scanner would poll supported parameters, my config didnt seem to capture any histogram data, the graphs were plotting, but the it wouldn't do anything when asked to read dtcs
    384whp/303wtq
    Sep 2002
    Chicago, IL
    6,397
    e-mail support with your tune, and a vcm suite info log connected to the vehicle.
    May 2010
    Dallas Texas
    321
    the vehicle is no longer in the shop. I can send tune file tho
    384whp/303wtq
    Sep 2002
    Chicago, IL
    6,397
    That wont' help much.
    May 2010
    Dallas Texas
    321
    wish I could figure out my config histos into the new graph formats
    384whp/303wtq
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by Japeatr View Post
    It is basically the same with the exception the term "PID." no longer is required i.e [PID.6001] is now just [6001]. If you click the 1-9 it will open the parameter with its identifier number. If you click the little gear with the green check, it will remove all parameters that aren't included in the Channel table. The Tables that we had in 2.24 are gone but its just as easy to go into the editor, find the table you want, right click on a column or row axis, hit copy labels and then go to the axis input are in 3.0 and paste. Don't forget to select the right parameter (try and use sensors when ever you can) and also make sure that parameter is in you channel table as well. Pretty close to 2.24.
    Also, Keith has put up a great on-line help section (search for the link) to help you through the transition.
    Ed M
    [email protected]
