Ok here is the story. I have paid a person to set it up and tune it. He never got it going paid in advance. Surprise! I have bought a hp tuner and started leaning. I would like a person to look over my tune and give advise. I have set it up with sd and 2 bar. When 2 bar map is in it starts runs for a few min with intercooler tube off and dies. If u put the intercooler tube back on it runs till it sees boost then dies after. After it does there is no throttle movement. Cycle the key a couple time it works again. If I remove and put the 1bar in it starts runs fat. When it hit boost it cuts out, which I understand its cause it does not read over 105 on the map. Running a drive by wire 2004 computer and harness on a 2000 5,3. Motor spec are 5.3, cam 228/230 .580 113 lobe separation of the top of my head. Headers 2.5 with x pipe magnaflows.Stock heads and all internals. 43lb green svo injectors on 60lb fuel pressure. From my understanding they figure to be about 60 lb setting on the hp tuner. PS1C procharger 8 psi with very large intercooler. I believe the 2 bar map is a piece.
Justin SWB 02 V8 2BAR.hpt
