I was just about to post the things you asked for when I realized I was also logging equivalence ratio commanded. could this be the cause?
[email protected]
Here's what you asked for. Thanks for the help. P.S. it's a very short idle log.
No AFR.hplAFR_Error AEM.MathParameter.xml1Bar SD Graph.Graphs.xml1Bar SD Channel.Channels.xml
Need your chart.xml as well please
Ed M
[email protected]
OK seems like you were using the wrong math parameter for your error. Should have used the AFR error (see screen shot). Also included updated Graph and Chart group for CMD AFR_WB AFR and AFR Err.
ERM P T Updated Graph.Graphs.xmlAFR Err.Table.xmlAFR CMD_AEM WB_AFR Err group.Chart.xml
Ed M
[email protected]
Crap sorry.
Ok I'll give that a shot thanks so much. Will that also be the fix for the MPVI.1 input not getting data for the WB in the graph and chart?
No you dont need that channel. When you first added that channel, it took the analog input into the MPVI, then you tell the software how to "scale" the voltage into your desired parameter, which in this case is AFR. You transform the MPVI analog channel into your AEM WB input. That is why you see MPVI.1--> AEM in the Channel table. Delete that channel that says MPVI.1.
Ed M
Here is a screen shot of the transform operation and equation that the software uses to calculate the AFR from the input voltage.
[email protected]
Ok and to make sure I have it strait. I need to delete MPVI.1 from the Channel. And I only need AFR Commanded in the channel right? Or do I need to add AFR error to it also? Other than that I think I've got it.
You need the AFR commanded and obviously the MPVI.1-->AEM channel. AFR Err is a Math Parameter and doesn't need to nor can be added to the Channel. Math Parameters are not a part of the Channel table, only Chat and Graph.
Ed M
[email protected]
Ok makes sense. Thanks again for your help. I'll try tomorrow and if you hear nothing all is well.
Hey guys, don't mean to hijack here but I'm having a similar issue.
I'm using an AEM wideband into my egr parameter which works fine, but I can't get the AFR ERROR math to work properly. Im pulling hairs over here
Would someone be able to help me out?
Sorry if I've missed anything, extremely busy at the shop today, trying to juggle 10 things at once
AFR EGR FACTOR.MathParameter.xml
I fixed it--use this math parameter in a chart/graph/whatever
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
You had a parenthesis in the wrong place I think, but that one should work
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
subscibed
2003 MY Z06 3.3 liter whipple ...sold at around 1000 rwhp
wip 2015 Silverado w/2.9 Whipple (phase 1 completed) phase 2 in the works
