Results 1 to 12 of 12
Thread: Tables and parameters we dont see with hp tuners
    Apr 2005
    42
    The more I use this software the more I am beginning to think there are extra parameters and tables we dont have access to. For example I was having problems with getting a consistent afr with pe. I would change the value and the 02's wouldnt relate it but if I made several wot runs then it would start to fall in line and get close to commanded afr. This makes me think there is some sort of learning that goes on with PE that we dont have access to, this also leads me to think that even though the stock 02's are inaccurate at anything but 14.7 the pcm does rely on them when in PE mode.
    Is there any chance that some of this stuff is changed with 2.0 or am I completely off?
    Nov 2002
    Central Florida
    2,503
    Re: Tables and parameters we dont see with hp tune
    I know there is way more to be discovered and
    untangled within the PCM. Even just the data
    section. All kind of stuff "gets done".
    I figure in a few years there will be serious OS
    rewriters that will also change the face of tuning
    (imagine being able to run an OS that wasted no
    time on diagnostics or mixture dithering, had a
    built in facility for nitrous control and other James
    Bond buttons, had higher maximum data limits
    for things like airflow and pressure and so on.
    Then again, the notion of a GMPP intake, a
    Dominator carb and HEI does have a certain
    raw appeal.
    PE does not learn, but PE will be pushed by bad
    learning, or learning of bad conditions. O2s drive
    learning. O2s need heat and so on. Follow the
    yellow brick road....
    I hear in Rel 3.0 we get to command the winged
    monkeys.
    Apr 2005
    42
    Quote Originally Posted by jimmyblue
    raw appeal.
    monkeys.
    As long as I get some magic slippers in version 3.0 Ill be happy. What your talking about would be cool.
    Quote Originally Posted by 02sierraz71
    PE mode doesn't learn, the only thing that will alter your fueling is varying positive fuel trims. If you are using the narrowband O2's as a tuning guide that is your problem right there.
    The PCM totally ignores all O2 sensor feedback in PE (or any other openloop) mode. It takes the commanded AFR, airflow and injector flow rate and determines injector pulsewidth without any corrections from the fuel trims unless positive.
    I count sheep in hex...
    Oct 2004
    Albuquerque
    77
    Check out the COT factor....It was controlling my fuel air multiplier.
    2007 VR z06...stock right now
    Apr 2005
    42
    Quote Originally Posted by S2002S
    Id like to know about the cot setting condition also, I competely removed mine. But I would think maybe if the rear 02's get really hot then it sets the cot not sure.
    figured out my PE problem I posted it here
    Oct 2004
    Albuquerque
    77
    I'm not sure how the COT condition is triggered. I have longtubes with relocated CATs that are way back, and you would think they would run cooler. I also was told when I had a recent emissions test (OBD-II read) that I had a catalyst secondary air o2 heater readiness monitor problem. The tester said that this was probably because the cats were not up to temperature. Go figure!
    Nov 2002
    Central Florida
    2,503
    COT tries to calculate up the cat temps based on
    exhaust airflow, mixture and that kind of thing.
    There are SAE science papers written on the
    algorithms but they're basically just a headache
    waiting to come on. Anyway, the PCM is predicting
    an overtemp condition based on assumed stock
    cat location and cooling and exhaust heat. With
    headers, it knows no different and will still dump
    fuel to prevent damage to something that isn't
    there, or is way cooler than "believed".
    If you want a little bit of protection then set your
    max COT to the same value as your max PE. But
    with stock cats this likely won't save them from
    cooking. It will however help for things like high
    RPM, stoich running which -could- hurt the cats,
    where PE-level enrichment would cost you only
    MPG. Less than total protection, less than total
    pig performance, maybe a viable compromise.
    But if you burn a cat don't come crying to me. I
    took the really safe route and put mine in a nice
    dry place.
    Apr 2005
    42
    I just took mine off god I love living in the south
    Oct 2004
    Albuquerque
    77
    :'( I'm already crying. Has anyone heard of a fried cat using long-tube headers (with COT disabled)?
    Nov 2002
    Central Florida
    2,503
    Has anyone heard of a fried cat ?
    What is this, a Vietnamese restaurant? ;D
    I think at really high exhaust flows the headers may
    not shed enough heat to save your cats from overtemp
    damage. Though I haven't heard much about this there
    was a guy on LS1Tech who was doing Salt Flats runs
    and cooked his, I believe that car had headers.
    Oct 2004
    Albuquerque
    77
    Fried cat is very tasteey.
    Thanks again for the advice!
