06 300C need help
hello,
I have tuned a 300c with a 5.7 in it, the cam specs are 224 228@50 113 lobe sep 546" valve lift.
after I do a flash the car runs really good, after about 6 or 8 drives it wont idle and turns the engine light on.
Map sensor out of range codes. it also has poor vacuum at idle the map reads about 65kpa, it this normal for a cammed 5.7? I'm using std lifters, do these give problems?
I attach the tune, any help would be greatly appreciated.. thankyou Eltonfinal tune.hptfinal tune.hpt
The file is locked. You need to unlock it for anyone to open it.
final tune unlock.hpt
try this one, sorry didn't relize it was locked
