Hey guys, new user here, so forgive me if I'm making a simple mistake. I had my buddy flash a base map (with efilive) in this bad boy to get it running, and now it's time to tune so I picked up HP Tuners. I read the stock file, and can edit it (used 2 credits, showed os/vin mismatch, shows a 2001 S10/Gen3 V8). This is in a 67 firebird so I didn't think anything about it. Under VE Table, it kPa goes up to 105, and Boost VE Table goes up to 285kPa, I've seen other tunes that are just under Main VE and are 0-315 for example. What's strange, is I have this thing forced into open loop and can adjust the MAP and see a difference, but the second it tries to go into boost, the wideband is pegged at 10:1 and it acts like fuel cut. I've got a cobalt SS 2 bar MAP and have the kPa and offset programmed into the VCM suite. I'm honestly not sure what I'm missing here. I didn't catch a log of the last run, but I took a quick drive to the gas station to fill the cell and captured that. I've attached the tune and the log, I hope it may help someone figure out why in the heck when I hit "OS" in the editor, I get a blank window.
PS - My controller is set to 5psi, and the motor is 8.5:1 on 91. I've got new wires and TR6 plugs gapped at .028"
