Page 8 of 12 FirstFirst ... 456789101112 LastLast
Results 141 to 160 of 231
Thread: NGK AFX vs. AEM 30-0300 CAN Comparison
  1. #141
    Sep 2007
    21
    Quote Originally Posted by dr.mike View Post
    That has been one of the advantages of using teh MPVI with the 30-0300 w/ the OBDII re-flash. The MVPI will record CAN data ( if present ) even on pre-CANBus cars. So, everything stays synched.
    e
    I have an E40, pre-CANbus, EFILive FSV2 and two LC-1's, using stream fast mode with 24 pids I can log at 10 frames a second / 10hz. Serial and annologue inputs are polled at the same rate. The LC-1 serial out is 12hz or anologue out is instant, 1/12, 1/6 or 1/3 with offset compensation, serial is better because FSV2 can only poll 10hz?
    The AEM 30-0300 can eliminate offsets completely, and in independent testing its response time is 20ms. I think I read that you have said the aem has T63 time ~10ms and the Lc-1 ~20ms, if I am correct, this is response time between the sensor and the aem gauge / LC-1 controller.
    The question I'm trying to answer is what I have already optimum with the E40 PCM, or whether I could consider upgrading to two aem and HPT MPVI to log 24 pids at higher than 10hz, I think I read elsewhere that the MPVI can poll 100 Hz or would I still be limited to 10 Hz of the class 2 network of the PCM? Can you connect two aem to the CANbus?
  2. #142
    Dec 2005
    604
    As far as I know, only the HPTuners MPVI can log CANBus data simultaneously with pre-CAN protocols like J1850, etc.
    That is the time it takes for the sensor and controller, together, to get to 63% of the proper reading. For example, if lambda suddenly went from 1.00 to 2.00, the t63 time is how long it takes for the reading to catch up and get to lambda 1.63 . It takes about 2 and a half times as long to get to 90% ( Lambda 1.90 ) etc.
    From my own measurements, the 30-0300 is about 10ms and the LC-1 is around 17ms for t63. The independent lab included the solenoid opening time in their measurements, which adds about 10ms to all of the units tested. Which seems to work out about right.
    What I, and some others here, have found is that there is much to be gained by logging at higher polling rates. Specifically, with the 30-0300, 100Hz works especially well. I'm pretty sure this is because of what I call "cell velocity". This is the rate at which changes in RPM and manifold pressure cause the current "cell" of the VE map to change. If the current cell changes 30 times a second, then lambda data from 100ms ( @10Hz ) ago can be 2 or 3 cells off.
    I think the polling rates are independent, per channel. But, obviously, the ECU limit still applies for those channels.
    Yes. Multiple AEM gauges can connect to the CAN bus. Specifically, this would be th 30-0333 version of the AEM gauge ( OBDII version ). Depending on your setup, you may need to add in a terminating resistor ( 68ohm ). But, that should be easy
  3. #143
    Sep 2007
    21
    Is anyone using AEM 30-0333 with an E40 that can confirm the polling rates of the wide band on the CANbus vs other pids on the J1850 VPW connection?
  4. #144
    Aug 2011
    Alaska
    566
    How does this thing work if it plugs into the OBDII port, and you also have the HPT interface that needs to plug into that port?
    What do I need to order? I'm a bit confused by the different part numbers, as shown on AEM's website, and what you see on vendor websites. I think the 30-0333 is the newest gauge version, but what's that come with?
    When arguing with an idiot, make sure he isn't doing the same thing....
  5. #145
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    They don't do a good job of showing it, but I'm almost sure the cable they include allows you to plug the WB into the OBD port then HPT into the WB. Kind of like this connector. It's called a "pass through" connector. Ignore the bare wires, etc. on the right.. this is just meant to show the connector itself.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Page 2 of the manual
    http://www.aemelectronics.com/files/...tion%20Kit.pdf
    Worst case you'd need an OBD Y cable off Amazon or eBay
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  6. #146
    Aug 2011
    Alaska
    566
    Thanks! I had no idea such widgets existed.
  7. #147
    May 2015
    21
    I am considering 2 30-0333's. I would need a splitter or a couple right angle adapters to make it all connect compactly. Would it slow down the response time?
  8. #148
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    The adapters won't make any difference---whether having two connected will effect response time, I have no idea. Dr.mike might know
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  9. #149
    Dec 2005
    604
    Technically, you would not need a splitter cable. As the pass-thru connectors can be "stacked". But, a chain of pass-thrus can be a bit unwieldy.
    Adding a splitter will not affect transfer speed. And, will probably make the installation cleaner.
  10. #150
    May 2015
    21
    Thanks for the quick response guys!
  11. #151
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Since I was hiding all the wires and Gauge anyway, I peeled back the two wires for Can H and Can L and soldered direct. Also thinking about cutting the constant 12v wire on the OBD connector and running it to switched 12v. That always drives me nuts for many reasons..
    #1 being when you plug the OBD cable into the MPVI box while the other end is in the OBD port and your short out the constant always on 12v pin to ground on the MPVI box, blowing a fuse, and usually leaving you without ability to tune or scan. And yes this is because I bought a 2nd cable and burried it under all the trim so the MPVI sits under the drivers seat, all tucked away.
    #2 being that is drains your battery being plugged in like that.
    #3 There is no reason for this.
    ZL1 Wheels/Tires
  12. #152
    Mar 2012
    Detroit, MI
    1,320
    Somewhere there was someone asking about the accuracy of the MPVI analog inputs... this is something I put together last year playing around using a calibrated power supply.., I dont question the error shown is the MPVI since the power supply used goes clear through 22volts, and only tested 0-5v, and you can see how the MPVI falls off above 4.5v. The power supply was verified to be under 0.3% error overall, and 0.1% or below between 0-5v shown here. I used to wonder why it was SOO heavy yet it only supplies 2amps MAX power... well now I know why.
    ZL1 Wheels/Tires
  13. #153
    Aug 2011
    Alaska
    566
    I want to buy one of these. Is there a particular part number or kit I should be looking at? I would like the latest/greatest version.
  14. #154
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    30-0333 Is what you want
  15. #155
    Tuning Addict
    6,804
    Schpenxel, yours ever show? Mine's been on order for a couple weeks now and still doesn't show to have shipped... Just wondering - I want to do some comparisons with it - won't be 100% accurate since it will be in a different bank, but never the less Anything that helps, is accurate and will hold up is good in my book...
    ~Greg Huggins~
  16. #156
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Mine finally shipped Friday.. Going to be here today actually
    Will probably be this weekend before I can install it though. I'm hoping to do the same comparison...
  17. #157
    Aug 2011
    Alaska
    566
    Where did you guys order them from? Direct?
  18. #158
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I got it off amazon but it shipped direct from aem
  19. #159
    Aug 2011
    Alaska
    566
    Thanks.
    Checked and found it. Then got the typical "cannot ship to your address". One of the joys of living in Alaska - shipping. Oh well, I'll find it somewhere else.
    I want to compare it to my NTK-AFRM.
  20. #160
    Jan 2009
    792
    Quote Originally Posted by Michael_D View Post
    Thanks.
    Off topic but where do you live in Alaska Michael? Our daughter is a dispatcher/911 operator in Fairbanks. She and her husband actually like it up there. Not many places you can be sitting in your living room and see a giant moose casually walk through your front yard! The worst part for her is how hard it is on their car and truck.
    Check out my V8 Sky build video. It's pretty cool!...
    https://youtu.be/2q9BuzNRc3Q
    https://www.youtube.com/user/gmtech16450yz
