I have an E40, pre-CANbus, EFILive FSV2 and two LC-1's, using stream fast mode with 24 pids I can log at 10 frames a second / 10hz. Serial and annologue inputs are polled at the same rate. The LC-1 serial out is 12hz or anologue out is instant, 1/12, 1/6 or 1/3 with offset compensation, serial is better because FSV2 can only poll 10hz?
The AEM 30-0300 can eliminate offsets completely, and in independent testing its response time is 20ms. I think I read that you have said the aem has T63 time ~10ms and the Lc-1 ~20ms, if I am correct, this is response time between the sensor and the aem gauge / LC-1 controller.
The question I'm trying to answer is what I have already optimum with the E40 PCM, or whether I could consider upgrading to two aem and HPT MPVI to log 24 pids at higher than 10hz, I think I read elsewhere that the MPVI can poll 100 Hz or would I still be limited to 10 Hz of the class 2 network of the PCM? Can you connect two aem to the CANbus?
