When i unplugg my MAF to log, My tranny shifts very hard?
The MAF is part of what sends the signal for the shift pressure, if I am not mistaken. Perhaps this means that the other parameters that are used when the maf signal is lost are off, causing the firm shifting since it can't adjust appropiately to the air coming in. Just a quess though.
Trans line pressure is set by calculated load, load is
airflow and RPM, with the MAF offline the airflow is
suspect and a failsafe, max pressure is used. Some
years / models will revert to use speed density load
and not make it default to full pressure, some just
go to "failsafe".
email me your .bin and i will fixup the trans stuff manually for you.
I count sheep in hex...
cym, give that a try.
Chris...
