Results 1 to 8 of 8
Thread: Tackling Torque Correlation
    May 2015
    1,908
    So I am trying to back into how the PCM is calculating torque and airflow, I see how HP Tuners laid it out in the formulas, but the math is simply not working.
    Here is the math...
    Airflow (g/sec) = (commanded torque (Nm) - Torque/Airflow Offset (Nm))/Torque/Airflow Factor (Nm/g/sec)
    When you divide the NM of torque by the factor, NM units cancel out and youre just left with g/sec...
    I have been logging the following channels:
    Powertrain Thottle TqReq - matches exactly to the table found in Engine>Torque Management>Auto Trans TqMgt, this is essentially your COMMANDED TORQUE for all intensive purposes
    Trans Engine Torque - appears to be your CALCULATED TORQUE
    So here is just one exact spot...
    900RPMS in gear at a stop
    Powertrain Thottle TqReq: 48Nm
    Trans Engine Torque: 101Nm
    Total Airflow: 19.2g/sec
    ECT: 181*F
    MAP: 68.4 kPa
    At 900RPMS, my tune has the following parameters:
    Torque/Airflow Offset: -14.84 Nm
    Torque/Airflow Factor: 11.75875 Nm/g/sec
    Friction Torque Loss: 39.5 Nm
    Flywheel Req. Tq - DR: 52 Nm
    So first off, a bit of a rounding issue but the Flywheel Req. Tq - DR is essentially equal to the Powertrain Throttle TqReq, which is what I expect...
    Now the Trans Engine Torque I am guessing is ACTUAL flywheel torque, either that or it is POST torque convertor torque multiplication, would would make some sense as most are around 2x multiple. But I see it move around a TON more than the torque commanded, and in fact when in park/neutral the commanded torque goes to zero but yet the trans engine torque remains populated, telling me its actual torque calculated.
    So now when I attempt to do the airflow calc using either one I don't get even close:
    Using Powertrain Throttle Torque: (52Nm - (-14.84Nm))/11.75875 Nm/g/sec = 5.68 g/sec
    Compare to my logged total airflow of 19.2 g/sec Not even close
    Ok so I thought maybe total airflow is calculated on actual torque calculated, could make more sense, here is that calc:
    Using Trans Engine Torque: (101Nm - (-14.84Nm))/11.75875 Nm/g/sec = 9.85 g/sec
    Still confused...anyone have any insight?
    May 2015
    1,908
    To me the math works if I just do:
    [commanded torque (Nm) / Torque/Airflow Factor (Nm/g/sec)] - Torque/Airflow Offset (Nm)
    (52Nm/11.75875) - (-14.84) = 19.26
    The math works, but then that means the "Offset" table is a g/sec offset not a torque offset.
    May 2015
    1,908
    Looks like my hunch is right, unless by some magic MIRACLE it works at every data point. Excel attached, if someone could populate their tunes info and check this against a log, it would be helpful, I going to try to dig up some tunes and logs from people and run it through this model.
    Based on this you have 3 ways to change your commanded airflow (commanded torque, factor, or offset). I had support map out the commanded torque in drive for my tune, not sure if others can see it.
    Commanded Airflow.xlsx
    May 2015
    1,908
    Seems to all be working out, I added modeling to the excel sheet based on the commanded airflow the expected TPS voltage, verified its working and matches my tune exactly.
    Jan 2015
    565
    Quote Originally Posted by 06300CSRT8 View Post
    Pardon my ignorance but what does this allow you to do? Scale the Desired airflow and desired tq?
    Nov 2017
    816
    Thanks for sharing this.
    Feb 2020
    Bethpage, TN
    15
    Thumbs up Pretty Cool!
    I'm looking at this for torque mutiplication for a current Dodge tune and this was exactly what I needed. thanks for posting
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    479
    Awesome work as usual
    04 RAMGTX........ 8.91@151mph 392Ci G3Hemi 3600lbs 2.6HP/Ci Naturally Aspirated
    05 RAMGTxtreme 9:45@142mph 426Ci G3Hemi 4000lbs 2.2HP/Ci Naturally Aspirated
    09 Challenger Drag Pak 8.88@150mph 376Ci G3hemi 3650lbs 2.6HP/Ci Naturally Aspirated
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
