Here is an example, I just threw a bunch of dupe pids together....maybe not the best most all encompassing example but nevertheless....
Undriven and driven wheel speeds.....why do these PIDs even populate?
Accel Position D, E, 1, 2, Avg and Throttle Position SAE....why do I have these and what are they for?
Two engine oil temps and then Engine Oil Temp Calc is so different?
Two Engine oil pressure pids, one doesn't even register?
Intake Air Temp 2 vs Manifold Air Temp.......
Total Knock Retard vs Knock Retard.......
Baro vs Baro SAE, look at 11m9s range and see how Baro SAE drops under WOT? Sup with that?
MAP Hi Res vs Intake MAP....big difference in the two, why?
Intake MAP A and B don't even work although they might if I log them without anything else in the list, but regardless, why even have them?
Ethanol vs Alcohol %......why have both?
I get having a broadcast pid AND the SAE version, sort of.....but that still adds an element of decision, discrepancy, and potential for error that we don't need. I don't remember having these issues in 2.2x either.
Also, when I add PIDs to my Channel List/Table they are all duplicated in the TCM section....why not just list the TCM stuff under TCM so I don't have to scroll and hunt through all the Engine PIDs, too?
Attachment 60773
