Results 21 to 40 of 49
Thread: Innovate LM-2 Issues
    Sep 2002
    Chicago, IL
    6,395
    Mark, sounds like you might have a wiring/voltage issue then.
    We got this guy Not Sure, ...
    Dec 2014
    Palmetto, FL
    874
    I fixed my initial issue.
    My issue now, is just not being able to get a stable reading. The afr reading on HPT jumps around to much to get correct data from.
    That was using, the analog wires from the LM-2.
    I have not tried the serial cable, because I need to purchase the cables to do so. But I was looking to find out if there was anything to make the analog setup work better. Or if I have to get the serial setup, and if the serial setup is even working better.
    I honestly just need something that is going to work best, the LM-2 was recommend as one of the wideband to use for vehicle to vehicle by Bill. So that is why I purchased the LM-2, and now to find out that I most likely need to get a different brand.
    http://www.hptuners.com/forum/showth...-right-for-YOU
    Sep 2002
    Chicago, IL
    6,395
    Well there's two reasons why it could be jumping around like that.
    1. The readings are accurate and the LM-2 is outputting varying data.
    2. The readings are inaccurate due to a wiring/ground/connection/voltage issue.
    Dec 2014
    Palmetto, FL
    874
    The wiring connections are all good.
    So I just messed with it more just now. And I set the filter in the scanner on the chart to 1,000 ms then set it to 2,000ms. And it got the chart to actually stabilize the reading, just slow and does still vary a small amount from the value measured on the display of the LM-2. But once you stop the log, and look back over the log it defaults the data back to as if there was not filter setting. So it goes back to impossible to read data.
    Here is what the input looks like with 0ms filter
    Here is what the input looks like with 2,000ms filter only while logging
    Here is what the input looks like with 2,000ms filter once stopped the log, to review the log
    Do I get another brand wideband? Or is there a fix for this issue?
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    You can make a math parameter that averages the data (and will stay after you stop recording)
    I'm running a PLX and don't have that issue
    Also am starting to use an aem 30-0333 which connects via the OBD port instead of being wired to the 0-5V input
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  6. #26
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    I have an LM2, an AFR500, an AEM 30-300 and two AEM 30-0310 inline units that were modified as part of a Beta for the AEM OBD solution. The only one I have had voltages issues with is the LM2. BUT by far the best is the OBD2 solution, which AEM sells as a 30-0333 with a gauge, they do not sell the 30-0310 as an OBD2 solution yet. I use the 30-0310 units in my car. Very fast, very accurate and no math or voltage offset or fluctuation issues. the AEM 30-0333 unit however does not ship with the pins populated for the serial or 5v populated and is only known to work on 2008+ cars at this point. Would never use anything else if I did not have to. There is a thread about these.
  7. #27
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    The -0333 works fine on my 2005 corvette over CAN bus
    I do wish pins were at least included to populate the other outputs...
  8. #28
    Sep 2015
    Bozeman, MT
    701
    Did you have to put in a resistor?
  9. #29
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Nope.
  10. #30
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by Mark@TuckerPerformance View Post
    I saw this post.. not sure if yours has the same offset compensation... read dr.mike's reply
    http://www.hptuners.com/forum/showth...l=1#post438801
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  11. #31
    Jul 2013
    Brisbane, Australia
    70
    I've just started using an LM-2 with NIStune and it connects via USB. Have yet to try it with HPTuners but I assumed there would be a driver so it connects directly to the software rather than through the interface. Can't this be done with VCM Scanner?
  12. #32
    Jun 2016
    22
    So how do you use HP tuners in conjunction with 30-0333 wideband when it's plugged into the obd port?
  13. #33
    Dec 2015
    Reno
    62
    Quote Originally Posted by TurboRick View Post
    Was going to ask this...need pics
  14. #34
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Very carefully
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  15. #35
    Dec 2005
    604
    I see by the pictures that they do not stuff the pins for the analog output wires, in the 30-0333 harness.
    You can get the pins here : http://www.digikey.com/product-detail/en/jst-sales-america-inc/SPUD-001T-P0.5/455-2518-1-ND/1989509
    Install pins 9 ( Analog Output + ) and 10 ( Analog Output - )
    Just in case the analog output is needed.
  16. #36
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I was very much hoping someone would post that info, thanks..
    I had been looking for them but wasn't sure which pins were the correct ones
    At $1.08 for 25 though I may have to wait until pay day before I can order them, lol
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  17. #37
    Jun 2016
    22
    Very carefully
    [URL=http://s1117.photobucket.com/user/caparris/media/2005%20Corvette/IMG_3157.jpg.html]
    That's a nice piggyback cable. Where do you get that?
  18. #38
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Comes with it the 30-0333 setup
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  19. #39
    Jan 2017
    Middleton, AUS
    27
    This thread seem to of got lost a couple of years ago and went off topic.
    Do you know if the issue Mark@TuckerPerformance was having has it been solved..?
    As Iam getting the same issue, wired to ground check, also run a button for a 5v signal as manual knock record works a treate anyway
    I can see Keith says config LM-2 to give better data, it seems that you get to pick 12, 6, 3 Hz or times per second, and the HP Interface samples the input at 10Hz by default and you cant change the polling interval (greyed Out) which would creates a sample rate miss match with LM-2, this is what i think is going on.
    or has it been solved..?
    After a couple of hours of playing with this I have come up with that the LM-2 Aux Output is square wave and not true sine wave and the HP Interface EIO is expecting a sine wave not square wave so when it average the square wave it samples on the tops and then on the bottoms of the square waves at different times to the LM-2 it's actually output is 12hz or 1/12 second, this is why VCM Scanner goes high and low on the AFR reading.
  20. #40
    Jan 2017
    Middleton, AUS
    27
    If anyone is interested, LM-2 AFR output Analogue Out 1 this is the issue, it is Pulse Width Modulated not true analogue.
    Ground offset is NOT the problem.
    I have built an Digital to Analogue converter, problem solved.
    It is now as stable as and accurate from 7.35 to 22.39:1 AFR.
    What ever is on the screen of the LM-2 is also in VCM Scanner.
