Greetings,
Long time lurker - second time poster here. I need some guidance on smoothing out the idle on my 2010 CTS-V, please.
It has upper/lower pulleys, modest cam with -9 degrees overlap, LS7 TB, CAI, post-boost meth/H2O injection, ZL1 lid, and tuning by me, a rookie tuner.
The idle is a little rough - it feels somewhat like a lean miss, but not a lope. If you look at the pic below, the left half is idling in gear and right half is in park. This is a screen capture from the attached log file. It's a 3-minute file where the car was warm started, driven around the block, and then parked in the garage to idle. There were four misses captured during this time. Idling starts in gear at the 2:26 point and continues in park at the 2:43 point.
Also, the O2 plots from the NB sensors are strange when idling or coasting. As soon as gas is applied, they smooth out.
The attached tune is currently set up as MAF only and is minimal until I get this figured out. Any help in fixing these issues is greatly appreciated.
