I'm having trouble working with the computer supplied by GM with one of thier crate motors. The paper work supplied says to treat it as a 98 F-body Automatic (With tech2 of course ), and I have 98 fbody. Niether one will read/write to computer, it won't even log it. All it will do is retrieve the VIN and read the battery voltage. The VIN is programmed as LS1 AUTO VER.0. When you try to talk to it, it gets as far as identifing the computer, and wigs out and stop after I assume they see the non standard VIN. I've tried everything from doing a complete reflash with an other 98 program to trying to just change the VIN thinking it would help. No dice, it won't let me do anything. I can scan it with a generic OBDII cable I have. Everything works, the car runs and drives we just need to change a few things specific to the installation.
I'm still using v1.7 because v2.x runs like a turd on my laptop. Is that computer supported in the later versions or do I need to add another vechical type.
