Results 1 to 5 of 5
Thread: Hiding or increasing cam lope tune ??!!
    Nov 2015
    25
    I am wounding what is the best way to either hide or increase cam lope on a Hemi using Hp Tuner?!
    Specifically on a 6.1 Hemi.
    For example: hiding cam lope on a cammed Hemi and make the sound of it close to a stock cam, or vise versa
    Thank you,
    I'm curious also!
    13,582
    Raise the idle rpm alot.
    Or run some really long mufflers that soak up all sound. I don't see any other way if you added a aftermarket camshaft.
    You wouldn't want to just start fudging numbers to get it to idle chop because that could cause you other problems.
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Increase the minimum spark in the idle areas.. Wont' give it much time to pull timing giving you the lope and you'll probably have to decrease idle airflow.
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Jan 2015
    Houston Tx
    77
    Raise idle and stock exhaust works the best.
    David McLain
    [email protected]
