Results 1 to 15 of 15
Thread: help please rpm hang between gears
    Jun 2016
    19
    c6 ls2 corvette m6 procharged runs good idles perfect just have that issue with rpm hanging between gears its really annoying could it be a vacuum leak?
    13,592
    Logs and tune files are the best way to get help.
    Need to see what's going on.
    Jun 2016
    19
    here s my tune i will post a log tomorrow.
    i appreciate the help
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    If you really want it to go down fast you can try turning CFCO back on
    Post a log when you get a chance.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Jun 2016
    19
    here it is looks like it only does it at low rpms.
    appreciate the help.
    Tuning Addict
    6,869
    I would recommend focusing on idle proportional and integral... This looks like an airflow issue - pulls timing, but throttle closes slow... Just an observation...
    ~Greg Huggins~
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I think so too. I've just been able to make RPM's fall super fast on mine with CFCO on (too fast probably), so figured that was an easy thing to try
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Jun 2016
    19
    ill tried the CFCO BACK on if not ill try to teak the idle proportional and integral.
    thanks i let you guys know what does the trick.
    Jun 2016
    19
    no luck by turning back on CFCO
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Ah well it was worth a shot
    In that case you're back to Greg's idea
    Nov 2009
    All Around
    3,149
    what throttle body you have?
    Jun 2016
    19
    102lsxr intake and a ls7 ported tb.
    Australia
    1,996
    could try the "idle" "rpm" "follower" tables for decr steps if u lower those numbers i believe it makes it faster go to lower revs less amount of steps to get back to idle, from 1600rpm one table (coast decr in drive) u have at 40 steps could try halving that see if it helps in those tables the others look ok
    Tuning Addict
    6,869
    Before adjusting the proportional and integral tables - try putting 5650 in the etc scaler then try this base running airflow table... This is fairly common with prochargers due to how much air they keep pushing... You really need a torque throttle follower table, but your ecm doesn't have that built into it... I just know from how little min air your running, it should be much less with rpms... You'll still mose likely have to adjust your idle airflow tables, but see how this does first...
    ~Greg Huggins~
    Tuning Addict
    6,869
    You'll also need to adjust your dfco settings, getting this back to working will help a lot too...
    ~Greg Huggins~
