what should your LED do when it is done warming up? mine stays on but then it starts blinking. is this right? i am getting so frustrated with it i am getting ready to pull it off and get another wideband.
It should blink for 30 seconds and then go solid. After you program it, turn the key off(if that's where your +12 is coming from) and then turn it on. It should warm up again and then go solid.
www.outlawpontiacdragseries.com
Come race with us in MA, PA, and VA!
2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
Stock:13.36@104
Mods in sig:[email protected]
You can also connect the serial output to your laptop and start the logworks software to see if the controller has an error reading or if it is warming up. Does it continue blinking as long as its powered? If so, that's an error. Count the # of blinks to see what error code you have.
99 Firehawk T/A NBM, M6, 403, TFS, Harrop, etc
it goes solid for a while then after driving around for a while it starts to blink.
how many blinks? the blinks are an error code
Mike Horist
00 WS6 (TA) | 04 WS6 (GTP Comp G)
Mike \\#at&\\ horist \\&dot$\\com
BOTH cars HP Tuners Tuned
Make sure its getting enough power and the ground is good.
Stock:13.36@104
thanks guys. i am going to double chech the wiring and in not i am going with the PLX m300.
