Results 1 to 7 of 7
Thread: can't go wide open please help me
    Apr 2006
    35
    I am running an 03 cav 2.2L auto. As a newbie I am having problems understanding the shift tables. I could really use a howto on using these tables. My current problem is when I go wide open on a closed track I can only reach speeds of about 110mph and then the tranny downshifts to 3rd. Thus going to instant redline at 7000rpm. How can I force the tranny to stay in overdrive so I can push it to about 6000rpm or 140mph? Ideally I would like to set it so that the car can't downshift when my speed exceeds 110mph. Can this be done?
    28,287
    can you post your hpt file please.
    Apr 2006
    35
    As you requested I attached a copy of the original factory scan. Thanx for the help
    28,287
    heres your answer
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Also, the WOT 3-4 shift rpm is 8192. Check the part throttle shift speed table,
    the 3-4 and 4-3 shift speeds need to be lowered at the higher tps ranges.
    Russ Kemp
    May 2006
    WPB, FL
    24
    if you lower the 3-4 shift rpm, it will shift again? i didnt think there was another gear, lol
    aurora ohio
    19
    so what did you end up doing to correct your problem? i assume i am going to run into the same thing..
