Results 1 to 15 of 15
Thread: tune with headers and cats removed?
    May 2007
    314
    Hi
    I am installing headers and probably removing cats as well on a 2015 Silverado 5.3L
    Should I disable ALL dtc's related to bank 1 and 2 sensor 2 ? can I completely remove these sensors?
    cot disable as well?
    Anything else that I need to do, before driving away and FUBAR'ing the whole show?
    thx
    2003 MY Z06 3.3 liter whipple ...sold at around 1000 rwhp
    wip 2015 Silverado w/2.9 Whipple (phase 1 completed) phase 2 in the works
    Tuning Addict
    Jan 2015
    6,819
    Kill Post O2 DTC's - Yes
    Remove O2's - might run into trouble on the gen 5's? They don't always like sensors - in general - being gone - rear O2's usually OK...
    COT disable - yes
    Engine Diag - Exhaust - Take care of those too...
    Sounds like You and Your Son are having fun on that truck
    ~Greg Huggins~
    13,570
    I'd leave the sensors plugged in and just zip tie them to the frame.
    Just to avoid possible issues.
    May 2007
    314
    it won't damage them to be heated, etc. yet no action....lol ??
    yes we are having fun...I see the light at the end of the tunnel...finally!!
    thanks again guys
    Aug 2009
    Calibrating
    3,374
    I've had no issues removing rear 02s on any Gen 5s I've tuned...
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2010
    Texas Hill Country
    3,299
    I have no rear O2 sensors in my 2016 Z06.
    May 2007
    314
    sounds good.....thx
    Oct 2005
    baton rouge la
    411
    I just did mine tlearlier this week. I ended up turning off everything on sensor 2
    Aug 2020
    30
    would
    Engine-exhust- catalyst-general need to be changed to reflect failure values? Should these values be high or low?
    Min is 63 degrees
    Max is 109 degrees currently would this screw up the tune?
    Dec 2019
    DFW, TX
    124
    those arent failure values. just hover over the tables to get a description of what they are. it just wont go into cat warmup on cold starts if you change these accordingly, which is fine since you dont have any. at least im assuming you dont since you revisited this 4 year old post lol
    FWIW, at least o 2018 truck, if the rear O2s are not plugged in, your fuel system readiness will not set, even if all the DTCs are turned off.
    Chased my tail for months with that.
    Aug 2020
    7
    I've got my rear o2's plugged in and have been waiting on the EVAP readiness to set for 3 weeks now. Pain in the butt.
    2014 Silverado - Long tube headers//Volant Intake//L86 Intake//L86 Throttle Body//3" Exhaust//AFP Tuning
    Aug 2020
    30
    bit of a dumb moment here but my bank 2 sensor 2 has had a wiring issue I have rewired it 2 or 3 times now because the original clip that held the wires together was caked in mud and had to cut it off. crying shame. from there it was a guessing game as to how they are wired. I think it is wired correctly just so the computer reads that they are there even if it fails or is bad or whatever.
    i have reset these values to fail the CAT's
    there is a full thread on my page going over what i have done to my nightmare of a franken truck. hahaha. Anyone who can help me tune this truck is a saint.
    this is a gen V btw so all threads and anything is difficult to find information.
    Post tune file...ill get you going in the right direction and give it a once over.
    Aug 2020
    30
    This is the most up to date tune file I have.
    I can get you a scan if need be.
    Please let me know what you think
    2.3 DOD dissabled.hpt
    2014 Silverado 5.3, 6.2 intake and throttle body, 4"specter cold air with K&N filter, Texas Speed long tube off-road Y pipe Cat delete, flow master super10x1,
    just bolt on's for now I don't want to add anything else until i can solve this build. Sorry for the delayed response my dude.
