Thanks guys - There is no compatible OS for the segment swap for 9360361 OS.
swapping over to OS 12212156 is what you have to do in my case as you guys have suggested and write entire
I have done this in the past on swap vehicles but on this one I was just trying to preserve his factory OS - 99 Firebird (probably just my OCD kicking in but seems like I have less trouble this way)
Man I got a 99 camaro computer (os id 9360361) in my car, I'm trying to do an 80 swap, and all research has led me to believe there's no 80 segment swap for my os id. My question is, if I credited a file in Another car (os id 12212156) could I simply write entire to mine? Or is there more to it? I've never did an os swap, tia
99-00 and 01-02 call out different service numbers, you can put the newer PCM & OS in the older car but I don't think you can write the newer OS to the older PCM hardware. Otherwise GM would just have a single number to cover them all.
