Thread: Hellcat help
    Nov 2014
    11
    Hellcat help
    I have a 16 hellcat in for pulley swap, long tubes, balancer, and cai. I received the computer back yesterday from the modification service and put it in. I cleared the codes as stated through the bi-directional controls. When I statred it the check engine light was on with no throttle control. So I shut it off and cleared the codes again with the bi-directional and the dtc menu and I clear all additives. Now I have throttle control but still have a check engine light with 9 DTC's for mostly throttle pedal and map sensor. P00FB, P0123, P012d, P0222, P1610, P1617, p2122, p2127, & u1424. SO I put the original PCM in and all is fine. Is this normal and I missed something or do I have a problem. If anyone has run into this and has advice I would appreciate it. Thanks
    Rob
    RTR Automotive
    [email protected]
    Rob Ryan
    RTR Automotive
    315-597-4142
    [email protected]
    Nov 2009
    All Around
    3,149
    i would contact who modded your pcm
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    Just a thaught, look up how to do a throttle re-learn. Maybe it will clear a few codes.
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Baltimore, Md
    1,208
    Quote Originally Posted by RTR View Post
    Rob
    RTR Automotive
    [email protected]
    What did you find ere
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
