Results 1 to 11 of 11
Thread: 01 4t65e converter
    Jul 2012
    Colorado Springs, CO
    42
    01 4t65e converter
    I am having difficulty with converter lockup on this 01 regal. If anyone can help, let me know!
    Built this transmission, put a high stall converter in it. I can not seem to get 2nd and 3rd gears to keep from locking up, which I do not want. In fact, most of the tcc tables seem to have no effect if modified. I have zeroed out the 2/3 release, maxed out the 2/3 apply, but it still does whatever it wants. The min/max tcc pressure does not seem to make any difference either.
    Any guess?
    13,595
    Got a tune file?
    Jul 2012
    42
    Ignore some of the weird settings....
    Was testing. to see if anything was effected.
    By the way, it is a 2900 stall converter, 4t65e w/ transgo shift kit and did a progressive boost valve
    13,595
    The converter shouldn't lock in 2nd gear. That why both tables stock are 255/254mph.
    If you don't want 3rd to lock up either you'd want to set both of those to max MPH speed too, so they don't lock up.
    Jul 2012
    42
    Attachment 63645
    I did this and it still applies in 2nd and 3rd
    13,595
    Attachment doesn't work.
    With the tune file you posted it needs to be above 256mph to apply in 2nd gear, so I have no idea what your problem is.
    Never had issues like this when I owned a grand prix, I didn't upgrade the converter but I've messed with 3-4th gear locking unlocking settings.
    Jul 2012
    42
    Well, it is from tune file. I dont know what my problem is either....Maybe there is issue with this pcm? Seems to be usual situation for what I work on...nothing works right.apply table.jpg
    13,595
    I'd even try flashing back to stock and going for a drive, see what happens.
    Jul 2016
    11
    TCC duty cycle's all set to 99 going over some other tune files they seem to drop off.
    Jul 2012
    42
    I had duty cycles set to normal, then I changed the DC to 99 just to see if it would apply correctly. Pulling trans back out this morning to make sure it's nothing mechanical.
    Jul 2017
    6
    Quote Originally Posted by joefus25 View Post
    This is what TCM?
