Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: High Flow Direct Injection Fuel Injectors and Pumps are here.....Redline Motorsports
  1. #21
    Aug 2009
    Calibrating
    3,378
    This week I?m tuning on a setup with the new 65%+ injectors, still waiting to here from company on changes for these...
    I?d much rather do Port injection on these engines.. Chris set me up with a very nice setup that I run a factory e38 on
  2. #22
    The injector data they provide did not work?
    Quote Originally Posted by Frost View Post
    Their data did not work for me.
  3. #23
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    It was very far off.
    Steve Williams
    TunedbyFrost.com
  4. #24
    Aug 2009
    Calibrating
    3,378
    Steve was that FIC or Xtreme DI???
    Been attempting to get ahold of Xtreme DI through email and calling for about 5 days.. pretty frustrating.
    2 emails sent and no reply and no option to leave a Voicemail.
  5. #25
    Jan 2006
    Richmond VA
    1,950
    Nostrum through Lingenfelter. They supply 3 different data sets and you match the set to a color sticker or something on the injector. On a previously, thoroughly calibrated truck, trimming was close to 30% after just the injectors and their data. I wanna say it wouldn't even crank without pedal following the swap. One of the units also would basically crap-up under boost and stop working until the truck came out of boost. It was very difficult to get it replaced.
    Steve Williams
    TunedbyFrost.com
  6. #26
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by Ben Charles View Post
    For what it's worth Xtreme DI seems active on instagram. Give them a try there.
  7. #27
    Aug 2009
    Calibrating
    3,378
    I wanted to update for anyone interested...
    Decided to reach out to Katech yesterday since they sell Xtreme DI products.. and after a couple of emails they told me just to change IFR. I agree with Howard/Banish and this is not the correct way to do it.
    Katech mentioned they would send an urgent email to Xtreme DI with our convo attached.
    I get an email this morning From Xtreme Di asking if I needed the 65% data and where I purchased them from??
    Honestly that shouldn?t even matter, not a happy camper right now and haven?t even started tuning on the car yet.
    BTW customer ordered directly from Xtreme, so gave them customer info and waiting to hear back
    Doing a 2650 on around 20psi on e85, I?ll be sure to keep anyone interested in how they tune
  8. #28
    Aug 2014
    Central, LA
    737
    Would you share the data if you get it?
  9. #29
    Aug 2009
    Calibrating
    3,378
    Of course.. injector data should be public knowledge base anyways
  10. #30
    Jan 2006
    Richmond VA
    1,950
    I had to "roll my own" data for them. Are these the same units?
    Steve Williams
    TunedbyFrost.com
  11. #31
    Advanced Tuner lt1z350's Avatar
    Mar 2014
    Dandridge, TN
    560
    If they are anything like the fic 30 percent ones I changed 3 tables they said to change and it ran great. I have tuned a few of the Ltg using the much larger then stock nostrum from 17 gs to 24 and doing the same tables on those the fuel trims dont even change enough to affect it. My zl1 was the same way stft from the before log to after log was damn near the same. So while you say this doesn’t seem good enough it works fine and now done it on a few cars all with the same outcome.
    First 9 second 6th gen lt4 zl1 stock blower SHC SBE boost only.
    2013 cadillac ats 2.0t Big turbo-gone
    2007 tahoe 5.3 lsa blower on 14 lbs boost 6l80e swap 2009 os
    2017 zl1 a10 big gulp/2 inch headers/ 9.55 lower/ e85/bigger hx /103mm tb / Synergy trunk tank and underhood kit/methanol injection with torqbyte controller and prometh pump / Jokerz performance R&D ported stock blower/ lme cnc heads /GP tuning custom cam. So far 9.30@150
  12. #32
    Anyone using these Nostrum injectors, lingenfelter fuel pump (in conjunction with low side upgrade and camshaft) at 700+rwhp on E85?
    I would think the HPFP would still not keep up.
    07 ZO6- warhawk 427/APS TT/HPT 2.5bar
    [email protected]
  13. #33
    Nov 2017
    11
    Bringing this back to the top. What was the verdict on XDI injectors? Did their tuning end up being good enough, and were you really able to hit 20 psi on full E85?
    I am Interested in getting their 30% hopefully during black Friday Sale.
  14. #34
    Aug 2009
    Calibrating
    3,378
    Made 22-23psi and had belt slip and changed upper pulley to I believe a 2.85 and was fine at 20! Injectors kept up at this level on pure e85 from memory and no meth.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  15. #35
    I've had the same issue with the Lingenfelter units. Dial in the car, runs great, issues. Swap injectors and pump using their data and car will hardly start. Fuel trims at 30% at idle and -20% light throttle cruise. Had to change the flow rate and small pulse adjust tables to get it close. Then fought with cold start on e85. Finally put it on the dyno and it was intermittently misfiring above 6k. Put the lt4 injectors back on in it and everything was good again.
    How was the driveability with these?
  16. #36
    Aug 2009
    Calibrating
    3,378
    With a 103TB, converter, and 23x24x drove great!
    14 Gen 5 Viper
  17. #37
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by 32vape View Post
    YES!!!! The set I had, had a unit that would "flub up" and begin a misfire in the same spot over 5K and then after boost/lifting, it would return to normal operation. It burned up a TON OF TIME. I'd share the data that I made up but I forget our "sticker color" (though I think it was green).
    Steve Williams
    TunedbyFrost.com
