Has any body been able to Fix, control, or bypass the Battery/Generator control unit that increases Idle speed under high load on the 2005 trucks.
Will a higher output alternator 200amp fix it or can you bypass the unit?
Is there a way to control it, are the control parameters going to be in the next release?
Thanks for any info.
