Thread: AEM 4110 with version 3.4 using serial - MPVI standard
    Dec 2015
    18
    Hi guys,
    I have my AEM hooked up through the EGR using version 2.24. AEM white analog wire to EGR pin on pcm, everything worked and I could log AFR.
    When I upgraded to version 3.4 it no longer logs. So I got a serial cable and wired the AEM blue serial output to Pin#2 of serial plug, and I grounded Pin#5 of serial plug. I then use a serial to usb adapter to the laptop (using windows 10). My laptop recognised the adapter and said it was operating correctly.
    When I add the channel in scanner and select the AEM, I then see it in the channel list. If I start log it just disappears. I tried the AEM EQ ratio and AFR, same problem. I then also "transform", and selected the parameter insert, and selected AEM 4110. When I start log, same result where it disappears.
    Any help would be appreciated.
    Thanks.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Did you start with the External Inputs>Serial Port then pick the AEM AFR or EQ Ratio.
    You can continue to log through the EGR or AC Pressure as previously. There is a video we developed to help you along with the new 3.X approach. https://www.youtube.com/watch?v=Ru_2M2uGSKs
    Ed M
    [email protected]
    Dec 2015
    18
    mowtown! Just want to say thanks for the guidance and how to video. Got it working again!
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by Mysta Joe View Post
    You are welcome and glad you got it straightened out...
    Ed M
    [email protected]
