TB closing
Hi,
I am tuning MB 2009 with supercharger, TB is closing at WOT. any thoughts ???
Desired air load need to be raised? Egt tq limit table. Can you post the tune?
Reason: forgot the file
Number 1: set this table to 100 across the board and test it out. Ill bet this is the majority of the issue
If it still closes after that, but less, open Engine -> General -> Desired Air Load and set the 100% column higher. Its around 110-105 stock, try 150 then 200 and see if that helps. If it does, then smooth that table afterward to not have a steep ledge of DAL at 100%
Your max desired throttle and max airload also appear to be stock. What variants are your car?
Many thanks for the effort. The customer will be back in 3 days, i will let you with the result. here is a log if u wanna have a look and variant are reflected too.
2.hpl
no change, still closing. here is a log... please help guys
222.hpl
Ill have to get the laptop out when I get home to check the log out. But, what did you change before testing?
I changed them all as you said. them I tried all possible things came to my mind....
many thanks for the effort
Did you change the max desired throttle and max airload tables as well?
Try disabling Spark Retard Allowed in torque management/general.
Please add the following parameters to your scanner and post a new log: Torque Limiting Active, Spark Intervention Active, spark torque management active, Fuel cut, Current percent of max torque, indicated torque, maximum permissible torque, model egt in manifold.
will do and let you know soon.
