http://forums.beyond.ca/showthread/t-117605.html for pics
VEHICLE HIGHLIGHTS:
LS2 6.0L V-8 with 400 horsepower and 400 lb.-ft. torque that exhales through a custom-built performance exhaust from the catalyst rearward
Heavy-duty 4L70-E four-speed automatic transmission with floor shifter
Heavy-duty 9.5-inch rear axle with a locking differential for added traction and a short 3.73:1 rear axle ratio for rapid acceleration.
Weighing in at under 3,500lbs and with Front disc brakes measuring over 12 inches that are sourced from the full-size Chevrolet Silverado; rear disc brakes from the Chevrolet TrailBlazer; the SS should have no trouble hauling to a stop.
Lowered suspension riding on brushed nickel-plated 20-inch Silverado SS rims
Stylized interior with unique trim, bezels, and seats
Custom exterior package with unique grille, fascias, flares, rocker extensions and tonneau cover.
GM reached back in its musclecar era for this SS hauler. An air-induction system, tailored straight from the '70 SS Chevelle platform, provides cool air from the windscreen. At high speeds, the windscreen will build air pressure at its base. This pressure will help the pistons fill the engine's cylinders through the air induction ducts.
