Results 1 to 8 of 8
Thread: Dodge Ram 6.7 2011 ECU does not answer after trying for read.
    Jan 2017
    Good day!
    It's my first message.
    I have a problem - after trying to read ECU on Dodge Ram 6.7 350 2011 - engine does not start.
    I read this DTC's
    U1601 - Restraint system dedicated bus #1 malfunction (Suppression system bus). ABS
    C2206
    C2202
    U0100
    U0141
    U0102
    U0415
    U0100
    U0141
    What goes wrong? Please help me.
    Dec 2018
    I just got my new MPVI2 this week for my 2011 RAM 5.7 and I get the same error about 3/4 the way through the scan. Did you ever get a solution?
    Thanks.
    Feb 2023
    Did anyone ever get any assistance on this? I just had the same problem when trying to read a 2010 Dodge Ram 3500 6.7L Diesel. I did not try to write anything to the ecm, only tried to read and it failed part way through and now the ECM has no communication. I had to pull the ecm and hook up on the bench to retrieve code U1601.
    Jul 2022
    i think i too in this same situation.... any solution?
    Feb 2017
    TX
    761
    Any one have an update on this??
    Tuner in Training Francuzzz's Avatar
    Aug 2016
    Kazakhstan
    47
    The same problem. Tried to read RAM 2011 and it shows sign that I need to turn off key and on, after that pcm doesnt read. U1601 ECU application software code 1 Missing or corrupted. Tried to connect with witech 2.0 but it doesnt read too((
    Jan 2022
    952
    Isn’t there a thread in the diesel section about bricking dodge diesels by trying to read em w HPT?
    I don’t do diesel but I heard no one is plugging a 2 or 3 into a dodge diesel bc of this
    Heard it from more than one person
    Feb 2017
    TX
    761
    I found out, yes, the ecm is done for. I'm sure there are other ways, $1800 for ECM and stock flash. There are no warning signs. IT WILL BRICK just by reading.
    It's not just 2 or 3, I used MPVI1.
