Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: Steering assist is reduced. Please drive with care After flashing
    I flash the stock tune after. Same
    Reflash entire. Same
    Unplug battery same.
    Can someone help me ??
    How long did you leave the battery unplugged for? Are you able to check for DTC's?
    2 min the battery
    no DTC.
    message went away after a ride of 2hours
    went back this morning
    Dec 2015
    Miami,Fl.
    292
    Mine shows the same thing every time I start the truck ever since I did the first read/write. Just never got around to emailing support...
    2023 Ford Maverick 2.0T AWD
    we email support and no one can help us.
    i reveived the answer : nothing related to the read/write processus.
    Dec 2015
    Miami,Fl.
    292
    Dec 2014
    Palmetto, FL
    874
    Did either of you two figure out the issue on your trucks of why the steering assist is reduced message was on?
    Just so happen this just happened on the 2017 Silverado that I did the 6.2L manifold and throttle body swap on, then tuning on.
    Dec 2015
    Miami,Fl.
    292
    Nope. I have to clear it with the cluster button every time I jump in the truck.
    Bumping this back up. Anyone find a solution? Just tuned a 2017 and it's been on ever since first flash.
    It should have set a C0 (chassis) code.
    I`m not sure that HP can read those codes?
    Is steering assist actually reduced or you are just seeing a (errant) message with the warning the dash?
    Don't notice any loss of power steering but who knows. I'll try and read the chassis codes with another scanner. Just ironic it happened after flash.
    Did the speed limiter get maxed out during the tune?
    Just a thought, but gen 5 does not like some tables maxed out.
    Quote Originally Posted by Earwax View Post
    My bet is a table is max'd out like the LS series engines, and for some reason the LT series don't like that variable . Example if your used to maxing your Speed limiter tables to 318, the newer computers aren't liking max'd out amounts so bring it down to a 225 amount.
    I read there was a recall for 800,000 trucks by chevy for steering assist problems.. just a fyi
    Thank you. The speed limiter was not modified in the tune.
    still have the message
    dont know how its happen
    Tuning Addict
    Jan 2015
    6,869
    Just post the tune so people can look through it to see what was changed - otherwise just a guessing game...
    ~Greg Huggins~
    In my situation, truck had a lost communication code with module. Cleared it with scanner and no more issues.
    Happen again with a reflash of a modification
