Results 1 to 5 of 5
Thread: 2009 pontiac g8gt 6l80e shift point question
    Tuner gmonde's Avatar
    Nov 2015
    farmington ct
    153
    just installed the lower gear ratio rear 3:45 (from a 2:92) ,, I have been working on the shift points @ full throttle and if any one knows the logic for the full throttle shift speed along with the full throttle rpm -example :I had the full throttle rpm @ 5500 and speed for 1-2 @ 25mph and 2-3 @55 mph ,, during the run it would hit the chip @ 6200rpm 1-2 shift and the same for the 2-3 ,, I took 5mph out of the shift speed table and it helped but any input would help me make educated adjustments ,thanks gmonde
    Aug 2009
    Calibrating
    3,378
    These things need to be mathematically dialed in... post the tune
    Tuner hivoltagedriver's Avatar
    Apr 2013
    Oklahoma
    50
    I set my WOT shift rpm where I want it to shift, and dial in the mph to make it happen. I can tell you that you are commanding too high of a mph to make it shift right with those gears. If I remember right, with 3.45's, I usually command a 1-2 around 24ish? and a couple of hundred rpm below the rest of the gears. I would have to open a tune when I get home tonight and take a look. 1-2 is usually the problem because it hits it so fast.
    I know with my 3.27s in my car, shifting at 7000, I command it at 27mph and 6800rpm for the 1-2, then 7000rpm for the rest.
    2017 JKU Rubicon: Purple, long arms, tons, 40s, Banks CAI, Borla cat-back, TD2/HPT tuned, daily.
    2017 GMC Sierra SLT: 6.2/ 8spd. Just getting started on it...
    Nov 2015
    farmington ct
    153
    [ATTACH]68121 here is the last change
    tunning school trans mod g8gt2 manual presure change-pe and maf gear change
    yeah I am at 20 mph and 5500 for the 1-2 shift it made a difference ,,I thought the shift calculation would have to be timed mathematically
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    Just use Bluecat's tool, makes it so much easier.
    https://www.hptuners.com/forum/showt...Table-Software
    Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
