Do you need the MAX 232 type interface for the 8192 baud port? If I can pull the voltage to 12v it should work with the 2 transistor type setup correct? (modified for voltage). I am actually designing a op-amp/transistor circuit for it that will translate the voltages to the proper RS-232 voltages but I dunno if there's anything else I am missing.. If not, I'll know sometime in the next 2 days (building power supply for laptop first).
This will only read for now..
