Results 1 to 6 of 6
Thread: Using 2003 4.8L computer on a 2003 6L
    Tuner in Training novaman996's Avatar
    19
    I have a stock 6L motor that im using, modified wire harness using DBW. I have a 2003 4.8L computer and a 2003 6L motor. Do I need to make changes to the fuel and spark tables or any other engine management setting.???
    Thanks Richard
    13,607
    Yes.
    If fuel injectors on the 6.0 are larger than the 4.8, that needs to be changed. The MAF curve and Primary VE need to match that of the 6.0. The cylinder volume needs to match that of the 6.0. The timing tables should be taken from the 6.0 and put into that tune.
    Tuner in Training CodeRed26's Avatar
    Jan 2017
    25
    Yes.
    wouldn't it just be easier to do a complete segment swap and then change minor things for the speedo ect.?
    Daily/Mud truck
    1994 Chevrolet K1500 5.3 swapped, BTR STG 4 truck cam (224/230 .553/.547 111+2), 0.030 milled 243s, NNBS intake, NV4500, 37s
    Project truck
    1992 Chevrolet C1500 single cab short box Big turbo LS, trucks are slow kk?.
    Why not get a stock 6.0 file from repository and flash it in?
    13,607
    Depends on who you ask. It would take literally less than 5 minutes to swap those mentioned tables and be on your way.
    It would take the same or more time if you had to find a 6.0 from the repository, use the segment swap feature and then have to go back and make more changes if you had different gear ratio and tire size or whatever else.
    Jan 2017
    25
    tbh how are you supposed to change said tables with out another tune file to tell you what they should be? (unless your a walking hard drive XD). Once you get the tune file and know what the tables should be sure it could take 5-10 mins but with the same file you need to get the tables correct you could just upload the tune or segment swap the engine stuff and be on your way in 30 seconds. 10 to 1 half a dozen of the other?
    Daily/Mud truck
    Project truck
