Results 1 to 3 of 3
Thread: LM-2 WB Analog Signal Wild - Can't dampen, help?
    May 2017
    15
    Question LM-2 WB Analog Signal Wild - Can't dampen, help?
    Hi there,
    Been searching for info with no luck:
    Using VCM with Pro interface and upgraded my DJ WBC wideband to a new LM-2 and now my scan has crazy, erratic readings. Waveform swings wildly in VCM Scan, but is solid as a rock on LM-2 local and their Logworks app.
    Tried deleting channel and re-adding as Analog In 1, Transform LM-2.
    No dice - tried filtering at 1000ms also.
    Anyone using an LM-2 with a nice smooth reading in VCM Scan clue me in!
    Thanks!
    May 2017
    15
    Bump for 3 days and no solution over here - anyone?
    Does HP provide support for the product?
    Australia
    1,988
    is the sensor earthed properly to the hpt module..? sensor input and earth to the pins on the module, i had a fuel pressure signal go crazy and it was because it wasnt earthed to the module only to the vehicle
